Package cleaning in the private warehouse
guestben321
Registration: Nov 30, 2021 - 4:38 p.m.
February 9, 2023 - 1:38 PM
I want to remove older package versions from my private repository.
However, some packages are still installed on clients, even though a newer version is available. This is probably because the client hasn't updated since or is no longer on the network.
So I have two questions:
- If I remove an older version of a package, for example 1.0.0, and this version is installed on a client, and there's a newer version on the server, will the client still install the update to 1.0.1?
- Is there a simpler way to clean up? For example, removing/or displaying only unused packages?
Thank you :)
WAPT Server Enterprise edition, version: 2.6.0.16552
olaplanche
Registration: January 26, 2017 - 11:11
February 10, 2023 - 09:12
1 - Yes, it is perfectly possible to remove an older version of a package without blocking updates on PCs that require it.
2 - In the "Private Repository" tab, uncheck "Latest version only," select a package, then press CTRL+A, right-click "Select obsolete packages," right-click again on one of the selected packages, and then "Remove from repository."
2bis - To see if a package is currently in use before removing it, select the package in the private repository and check "Show clients."
Regards
- Installed WAPT version: 2.6.0.16795 Enterprise
- Server OS: Linux / Debian Bookworm
