Page 1 of 1
PACKAGE (Uninstall then Install)
Published: February 23, 2023 - 5:04 PM
by Sylvain Thorez
I am currently creating some deployment packages myself:
In the `def install` function, I want to run `msiexec /x` commands to uninstall the old products and then install my version of the package
as follows for PDFSAM, but unfortunately it doesn't work. Thank you for your help
uninstallkey = ["{EE8AE69C-A8AF-4119-BB37-1631D3301E93}"]
    # Declaring local variables
    properties ={
    'CHECK_FOR_UPDATES':'false',
    'DONATE_NOTIFICATION':'false',
    'SKIPTHANKSPAGE':'Yes',
    # Uninstall the old version
    run('msiexec /x {0001B4FD-9EA3-4D90-A79E-FD14BA3AB01D} /quiet /norestart',accept_returncodes=[0,3010,1605])
    run('msiexec /x {8BD7882E-AF21-4327-9A48-333CAD22D3A1} /quiet /norestart',accept_returncodes=[0,3010,1605])
    run('msiexec /x {C123F44A-999B-4BED-98E7-D550ED14C94B} /quiet /norestart',accept_returncodes=[0,3010,1605])
    run('msiexec /x {BEF44F2E-322A-4B7B-8B15-16E31B602E6C} /quiet /norestart',accept_returncodes=[0,3010,1605])
    run('msiexec /x {0314BB4C-2B68-491C-B4FB-40F1EC6CA881} /quiet /norestart',accept_returncodes=[0,3010,1605])
    run('msiexec /x {EE8AE69C-A8AF-4119-BB37-1631D3301E93} /quiet /norestart',accept_returncodes=[0,3010,1605])
    # Installing the software
    print("Installing: pdfsam-5.0.3.msi")
    install_msi_if_needed('pdfsam-5.0.3.msi', properties = properties)
    # Uninstall the version
Re: PACKAGE (Uninstall then Install)
Published: February 24, 2023 - 9:51 AM
by dcardon
Hi Sylvain,
without an error message and the line where it happens, it's going to be difficult to say... :-)
