Page 1 of 1
packet tis-dotnet6
Published: February 28, 2023 - 12:45 PM
by vince86
I'm using the dotnet6 package (6.0.14.5) in 64-bit on a Windows 10 Education version 20H2 (windowsdesktop-runtime-6.0.14-win-x64.exe).
WAPT version: 2.3.0.13505 (rev c7fcb3a7).
It's probably related to a dependency of another platform that requires dotnet.
It's showing an error during auditing:
Auditing dotnet6
ERROR: Uninstall Key {96cf40b0-81d6-43ed-ad0e-611e67899196} is not in Windows Registry.
ERROR: Uninstall Key {ac916c06-1c22-495e-ae7e-b4e24fbbed14} is not in Windows Registry.
I haven't touched the package; it's the default one available in the TIS repository.
I saw that .NET version 7 was in the repository (I haven't tried installing it because I don't want to have both on my PC...).
Any ideas?
Regards,
Re: tis-dotnet6 package
Published: February 28, 2023 - 4:58 PM
by pcosson
Could you please check the version in the machine's software inventory and the version in the installed dotnet6 package?
I suspect an application packaged with dotnet may have downgraded your version.
Published: March 2, 2023 - 09:22
by vince86
On the PC: Microsoft .NET Runtime - 6.0.14 (x64) version 6.0.14.32123
Published: March 2, 2023 - 10:56 AM
by pcosson
Hello, so it's not a downgrade in your case. It seems Windows Update can update .NET; we'll work on a new audit to take that into account.
Regarding your question about .NET 6 and 7, they can coexist without any problems, and you might have applications that require both to be installed. Applications using .NET 6 are not compatible with .NET 7. .NET 5 recently reached end of support, so it forces you to juggle between versions a bit.
Published: March 6, 2023 - 2:15 PM
by vince86
Thanks. So, regarding the registry key errors, is it a problem with the WAPT package itself or with the machine (the software installed on the machine)?
Published: March 6, 2023 - 2:28 PM
by pcosson
a new version of the package that handles key changes has been released on the testing repository and will be published on the store in two days.
Regards
Published: March 6, 2023 - 3:03 PM
by dcardon
Hello vince86
vince86 wrote: ↑March 6, 2023 - 2:15 PM Thanks, so for the registry key errors, is it on the WAPT package side that needs intervention or is it at the machine level (software installed on the machine)?
Please refrain from posting links to external websites. The forum's purpose is to serve as an informal resource; if posts contain links to temporary image sites, it defeats that purpose. Please embed images directly in your posts, rather than providing links.
