Page 1 of 1
[SOLVED] Pyscripter - WAPT:install - Fatal error
Published: March 28, 2023 - 11:48 AM
by CasseThor
I wanted to give you feedback on a problem (which may not actually be one)
I created an .msi package and I'm getting this information from the console:
2023-03-28 11:28:16,883 CRITICAL Fatal error in install script: AttributeError: module '__waptsetup_sr4h0t49hx__' has no attribute 'install':
  File "C:\wapt\common.py", line 4074, in install_wapt
The manual package installation went smoothly
If I use the WAPT function: session-setup, I no longer get an error
Here is the script in question:
print('installation de Impact9')
run(r'impact9.msi /qn')
#print('installation de la licence')
#install_msi_if_needed('impact9_lic.msi' )
#run_notfatal(r'impact9.msi /q /norestart',timeout=1200)
I tried several installations, as you can see.
However, if I send the installation of this package to a remote machine, I get the same error:
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1907, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 710, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1282, in _run
Exception: Erreur lors de l'installation de ['iut-impact907(=9.0.0.0-5)']: erreurs dans les paquets [[PackageRequest(package='iut-impact907',version=(Version('9.0.0.0'), 5),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.22621.1413'),max_os_version=Version('10.0.22621.1413')), PackageEntry('iut-impact907','9.0.0.0-5' maturity='PROD'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5193, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4167, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4074, in install_wapt\n    exitstatus = setup.install()\nAttributeError: module \'__waptsetup_m4ojr8c7v2__\' has no attribute \'install\'\n']]
    self._run()
Re: Pyscripter - WAPT:install - Fatal error
Published: March 28, 2023 - 11:50 AM
by CasseThor
I should point out that the package on the computer does install correctly :)
. Regards
Published: March 28, 2023 - 3:09 PM
by dcardon
I think one is missing
There's a wizard in the console to prepare a package; it's quite handy as it automatically creates the package skeleton.
Published: March 29, 2023 - 3:49 PM
by CasseThor
Ah, thank you, but... no, something else must have been missing. :)
Anyway, I followed your advice to use a clean database with the wizard, and everything works!
Thank you. :D
Re: [SOLVED] Pyscripter - WAPT:install - Fatal error
Published: March 29, 2023 - 5:32 PM
by dcardon
Thanks for the feedback, CasseThor. :-)
I'm locking the thread.
