Page 1 of 1
Best practice: adding TIS as a repository or using import?
Published: August 30, 2015 - 8:06 PM
by markham
I would like to know if it is recommended to use the Wapt repository directly to benefit from the latest software for my network, or if it is preferable to proceed with a manual import as versions are released
. Thank you.
Published: August 31, 2015 - 08:38
by sfonteneau
Here's what I can say:
If you use the tranquil.it repository directly, you need a good internet connection because if you have a large network, all the PCs will download the new WAPT packages directly online.
