How TIS-TEMPLATE-MICROSOFT-STORE-APP Works
Published: June 1, 2023 - 4:31 PM
I want to use the TIS-TEMPLATE-MICROSOFT-STORE-APP package to install the Power BI desktop application
However, when I run the update package I get the following error
I don't understand where I'm going wrong, can you help me?
Thank you so much
WAPT Enterprise version: 2.2.1.11957
OS Server: Debian Bullseye
Operating system of the administration machine: Windows Server 2019
File "D:\wapt\waptpackage.py", line 2968, in call_setup_hook
raise EWaptMissingPackageHook('No %s function found in setup module for %s' % (hook_name, setup_filename or self.asrequirement()))
waptpackage.EWaptMissingPackageHook: No update_package function found in setup module for C:\Users\ADMINI~1\AppData\Local\Temp\4\wapt-20230601-16272600000.tmp\cam-microsoft-powerbi-desktop_2.117.984.1_windows_10.0_DEV-wapt\setup.py
Thank you so much
