Page 1 of 1
Identical UUIDs?
Published: September 10, 2015 - 2:36 PM
by Alan
some posts disappear from my list, then reappear, and so on.
After checking, it appears they have the same UUID, e.g.,
ELIOR-P01 FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF;
ELIOR-P03 FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF;
What is causing this?
What is this UUID based on?
A sysprep command was indeed run on the machine.
Thank you in advance.
Re: Identical UUIDs?
Published: October 12, 2015 - 11:33
by sfonteneau
This is a BIOS bug on certain manufacturers.
You can correct this with the order on the relevant customer.
wapt-get generate-uuid
This will generate a random UUID and store it in c:\wapt\wapt-get.ini
