EDT Client Package v2023 build 0.1.0
Published: June 19, 2023 - 09:48
I'm sharing my package for the edt v2023 x64 client:
Remember to replace the SERVERNAME, SERVERPORT and NOMETAB variables with your values
The new code automatically handles the possible presence of the previous version as well as the def update_package() function to simplify the update.
Using the same code, it is therefore possible to install the latest version side-by-side with the previous version seamlessly.
To uninstall the previous version, you must therefore use the uninstall function of the package of the previous version.
setup.py:
control:
setup.py:
import platform
# Defining variables
bin_contains = 'Install_EDTclient_FR_'
app_uninstallkey = '{FEC47E39-28BC-4549-A7F3-11E27A60911A}'
edition = 'v2023.0'
SERVERNAME = 'RNE.index-education.net' # Le nom DNS du serveur pronote
SERVERPORT = '49300' # Le port TCP du serveur pronote
NOMETAB = 'MonETAB' # Utilisé pour personnaliser le nom du raccourci sur le bureau
# Initializing variables
package_version = control.version.split('-',1)[0]
bin_name = glob.glob("*%s*.exe" % bin_contains)[0]
edition_old = str(int(edition[1:5]) - 1)
# Installing the package
print('Installing: %s' % bin_name)
import tempfile
import codecs
pathinstallfile = makepath(tempfile.gettempdir(),'Setup.iss')
if installed_softwares ('INDEX EDUCATION - Client EDT %s - 64bit' % edition_old):
data = r"""[InstallShield Silent]
Version=v7.00
File=Response File
[File Transfer]
OverwrittenReadOnly=NoToAll
[%s-DlgOrder]
Dlg0=%s-SdLicense2Rtf-0
Count=6
Dlg1=%s-SdAskDestPath-0
Dlg2=%s-AskOptions-0
Dlg3=%s-AskOptions-1
Dlg4=%s-AskOptions-2
Dlg5=%s-SdFinish-0
[%s-SdLicense2Rtf-0]
Result=1
[%s-SdAskDestPath-0]
szDir=C:\Program Files\Index Education\EDT %s\Réseau\Client
Result=1
[%s-AskOptions-0]
Result=1
Sel-0=0
[%s-AskOptions-1]
Result=1
Sel-0=1
Sel-1=0
Sel-2=0
Sel-3=0
[%s-AskOptions-2]
Result=1
Sel-0=0
[%s-SdFinish-0]
Result=1
bOpt1=0
bOpt2=0
""" % (app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,edition[1:5],app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey)
Version=v7.00
File=Response File
[File Transfer]
[%s-DlgOrder]
Count=5
Dlg4=%s-SdFinish-0
Result=1
Result=1
[%s-AskOptions-0]
Result=1
Sel-0=1
Sel-1=0
Sel-2=0
Sel-3=0
[%s-AskOptions-1]
Result=1
Sel-0=0
[%s-SdFinish-0]
Result=1
bOpt1=0
bOpt2=0
""" % (app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,edition[1:5],app_uninstallkey,app_uninstallkey,app_uninstallkey)
fichier = codecs.open(pathinstallfile, "w", encoding='mbcs')
fichier.write(data)
fichier.close()
install_exe_if_needed(bin_name,silentflags='-s -f1%s' % pathinstallfile,key=app_uninstallkey,min_version=package_version,killbefore='Client EDT.exe')
uninstallkey.remove(app_uninstallkey)
# Deleting response file
remove_file(pathinstallfile)
# Creating desktop shortcut for all users
create_desktop_shortcut(r'EDT%s - %s' % (edition[1:5],NOMETAB),target=u'C:\Program Files\Index Education\EDT %s\Réseau\Client\Client EDT.exe' % edition[1:5],arguments=r'-Adresse "%s" -PortTcp "%s"' % (SERVERNAME,SERVERPORT))
def audit():
if not installed_softwares ('Mise à jour automatique'):
print('Module de Mise à jour automatique manquant')
return "ERROR"
if not isfile(r'%s\InstallShield Installation Information\%s\setup.exe' % (programfiles32,app_uninstallkey)):
print('Binaire de désinstallation manquant')
return "WARNING"
for soft in installed_softwares ('Mise à jour automatique'):
print(soft['name'] + " : " + soft['version'])
return "OK"
def update_package():
print('Downloading/Updating package content from upstream binary sources')
bin_name_string = 'Install_EDTclient_FR_%s.%s_win64.exe'
proxies = get_proxies()
if not proxies:
app_name = control.name
url = control.sources
app_arch = control.architecture
if app_arch == 'x64':
dl_arch = 'win64'
dl_arch = 'win32'
# Getting latest version from official website
page = wgets(control.sources,proxies=proxies)
for line in page.splitlines() :
if ('CLIENT %s - 0.' % edition[1:5]) in line :
version = line.split('-')[-1].split('<')[0].replace(" ","")
break
latest_bin = bin_name_string % (edition[1:5],version)
url_dl = 'https://tele3.index-education.com/telechargement/edt/%s/exe/Install_EDTclient_FR_%s.%s_%s.exe' % (edition,edition[1:5],version,dl_arch)
print("Latest %s version is: %s" % (app_name,version))
print("Download url is: %s" % url_dl)
# Downloading latest binaries
if not isfile(latest_bin):
print('Downloading: %s' % latest_bin)
wget(url_dl,latest_bin,proxies=proxies)
# Checking version from file
version_from_file = get_version_from_binary(latest_bin)
if version != version_from_file:
os.rename(latest_bin,bin_name_string % (edition[1:5],version_from_file))
version = version_from_file
control.version = '%s-%s'%(version,int(control.version.split('-')[-1])+1)
print('Changing version to: %s in WAPT\\control' % control.version)
# Deleting outdated binaries
# Uninstalling the package
print('Uninstalling: %s' % control.package)
import tempfile
pathuninstallfile = makepath(tempfile.gettempdir(),'Uninstall.iss')
Version=v7.00
File=Response File
[File Transfer]
[%s-DlgOrder]
Dlg0=%s-MessageBox-0
Count=2
Dlg1=%s-SdFinishReboot-0
[%s-MessageBox-0]
Result=6
[%s-SdFinishReboot-0]
Result=1
BootOption=0
""" % (app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey,app_uninstallkey)
fichier = open(pathuninstallfile, "w")
fichier.write(data)
fichier.close()
run(r'"%s\InstallShield Installation Information\%s\setup.exe" -s -uninst -f1%s' % (programfiles32,app_uninstallkey,pathuninstallfile))
remove_file(pathuninstallfile)
# Removing desktop shortcut for all users
remove_desktop_shortcut('EDT%s - %s.lnk' % (edition[1:5],NOMETAB))
# Uninstalling Auto Update Agent
if uninstall_key_exists('{775E087D-A428-428C-A5FD-000010010000}'):
run('"MsiExec.exe" /X{775E087D-A428-428C-A5FD-000010010000} /qn')
architecture : x64
sources : https://www.index-education.com/fr/telecharger-edt.php
