Page 1 of 1
[RESOLVED] WAPT package for Brave
Published: July 7, 2023 - 10:28 AM
by SeiyaGame
I would like to offer you a package I designed for installing the Brave browser. Its creation was inspired by the tis-chrome package, given that the two browsers share the same foundation.
I have performed the installation, uninstallation and update of the package.
In this package, I have also integrated the ADMX files for GPOs, a feature that might interest some users.
Since I cannot upload the archive .waptI'm going to share the function code with you.
Here is the file code setup.py :
app_scheduled_tasks = ["BraveSoftwareUpdateTaskMachineCore", "BraveSoftwareUpdateTaskMachineUA"]
app_services = ["BraveElevationService", "brave", "bravem", "BraveVpnService"]
    # Declaring local variables
    package_version = control.version.split("-", 1)[0]
    bin_name = glob.glob("brave_installer_*.exe")[0]
    skip = False
    if isdir(makepath(programfiles32, "BraveSoftware", "Brave-Browser", "Application")):
        brave_app_path = makepath(programfiles32, "BraveSoftware", "Brave-Browser", "Application")
        brave_app_path = makepath(programfiles, "BraveSoftware", "Brave-Browser", "Application")
    brave_bin_path = makepath(brave_app_path, "brave.exe")
    app_uninstallkey = "BraveSoftware Brave-Browser"
    def get_version_brave():
        return get_file_properties(brave_bin_path)["ProductVersion"]
    if windows_version() < WindowsVersions.Windows10:
        # Uninstalling newer versions of the software
        for to_uninstall in installed_softwares(name="^Brave$"):
            if Version(to_uninstall["version"]) > Version(control.get_software_version()) or force:
                print("Removing: %s (%s)" % (to_uninstall["name"], to_uninstall["version"]))
                try:
                    killalltasks(control.get_impacted_process_list())
                    run(uninstall_cmd(to_uninstall["key"]))
                    wait_uninstallkey_absent(to_uninstall["key"])
                except Exception as e:
                    print(e)
                    print("Remove failed: %s (%s)\nContinuing..." % (to_uninstall["name"], to_uninstall["version"]))
    # Installing the package
    if isfile(brave_bin_path):
        if Version(get_version_brave()) >= Version(package_version):
            if uninstall_key_exists(app_uninstallkey):
                uninstallkey.append(app_uninstallkey)
            skip = True
    if (not skip) or force:
        print("Installing: %s" % bin_name)
        install_exe_if_needed(
            bin_name,
            silentflags="--install --silent --system-level --qn",
            key=app_uninstallkey,
            min_version=package_version,
    # Disabling application scheduled tasks
    for task in get_all_scheduled_tasks():
        if task.split("{")[0] in app_scheduled_tasks:
            if task_exists(task):
                try:
                    disable_task(task)
                except:
                    print("Unable to disable the task: %s" % task)
    # Changing default start mode of the application services
    for service_name in app_services:
        set_service_start_mode(service_name, "Manual")
    # Disabling Brave Auto-Update and Reporting
    registry_setstring(HKEY_LOCAL_MACHINE, r"SOFTWARE\Policies\BraveSoftware\Brave", "ComponentUpdatesEnabled", 0, type=REG_DWORD)
    registry_setstring(HKEY_LOCAL_MACHINE, r"SOFTWARE\Policies\BraveSoftware\Brave", "MetricsReportingEnabled",  0, type=REG_DWORD)
    # # Adding master preferences file (instead, we recommend that you to create a package like tis-brave-config)
    # filecopyto("master_preferences", brave_app_path)
    # Uninstalling the package
        if not "msiexec" in " ".join(list(uninstall_cmd(app_uninstallkey))).lower():
            versionsoft = get_file_properties(brave_bin_path)["ProductVersion"]
            run(
                '"%s" --uninstall --system-level --force-uninstall --qn'
                % makepath(install_location(app_uninstallkey), versionsoft, "Installer", "setup.exe"),
                accept_returncodes=[19],
def session_setup():
    # Needed on Brave ??
    swreporter_path = makepath(user_local_appdata, "BraveSoftware", "Brave-Browser", "User Data", "SwReporter")
    if isdir(swreporter_path):
        print("Removing: %s" % swreporter_path)
        remove_tree(swreporter_path)
Here is the file code update_package.py :
from setupdevhelpers import *
import re
import json
def update_package():
    result = False
    proxies = get_proxies()
    if not proxies:
    app_name = control.name
    url_api = "https://api.github.com/repos/brave/brave-browser/releases/latest"
    url_dl = "https://brave-browser-downloads.s3.brave.com/latest/brave_installer-x64.exe"
    # Getting latest informations from official Google API
    json_load = json.loads(wgets(url_api))
    tag_version = json_load['tag_name'][1:]
    chromium_version = re.search(r"Chromium (\d+(?:\.\d+)+)", json_load['name']).group(1)
    version = f"{chromium_version.split('.')[0]}.{tag_version}"
    latest_bin = f"brave_installer_x64_{version}.exe"
    print(f"Latest {app_name} version is: {version}")
    print(f"Download url is: {url_dl}")
    # Downloading latest binaries
    if not isfile(latest_bin):
        print("Downloading: " + latest_bin)
        wget(url_dl, latest_bin, proxies=proxies)
        # Get version from description exe
        exe_version = get_version_from_binary(latest_bin)
        if exe_version != version:
            remove_file(latest_bin)
            error("The version returned by the API and the version returned by the exe does not match")
    if Version(version) > control.get_software_version():
        print("Software version updated from: %s to: %s" % (control.get_software_version(), Version(version)))
        result = True
        print("Software version up-to-date (%s)" % Version(version))
    control.version = "%s-%s" % (Version(version), control.version.split("-", 1)[-1])
    # control.set_software_version(Version(version))
    # Deleting outdated binaries
    # Validating update-package-sources
    return result
And finally, the file control :
package           : loq-brave
version           : 114.1.52.129-3
architecture      : x64
section           : base
priority          : optional
categories        : Internet
maintainer        : Flavien Schelfaut (Loquidy)
description       : Brave is a free and open-source web browser developed by Brave Software, Inc. It blocks ads and website trackers, and provides a way for users to send cryptocurrency contributions in the form of Basic Attention Tokens to websites and content creators
depends           :
conflicts         :
maturity          : PROD
locale            : all
target_os         : windows
min_wapt_version  : 2.1
sources           : https://laptop-updates.brave.com/latest/winx64
installed_size    : 684132243
impacted_process  : brave,chrome_proxy,chrome_pwa_launcher,chrmstp
description_fr    : Brave est un navigateur web gratuit et open-source développé par Brave Software, Inc. Il bloque les publicités et les traqueurs de sites web, et permet aux utilisateurs d'envoyer des contributions en crypto-monnaie sous la forme de jetons d'attention de base à des sites web et à des créateurs de contenu.
description_pl    :
description_de    : Brave ist ein freier und quelloffener Webbrowser, der von Brave Software, Inc. entwickelt wurde. Er blockiert Werbung und Website-Tracker und bietet Nutzern die Möglichkeit, Kryptowährungsbeiträge in Form von Basic Attention Tokens an Websites und Inhaltsersteller zu senden
description_es    : Brave es un navegador web gratuito y de código abierto desarrollado por Brave Software, Inc. Bloquea los anuncios y los rastreadores de sitios web, y permite a los usuarios enviar contribuciones en criptomoneda en forma de Basic Attention Tokens a sitios web y creadores de contenidos.
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : Brave Software, Inc.
keywords          : browser,navigateur,brave,chromium
licence           : MPL-2.0
homepage          : https://brave.com/
package_uuid      : 4774f883-f37e-4cba-8e8d-3843983f4836
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://brave.com/latest/
min_os_version    : 10.0
max_os_version    :
icon_sha256sum    : 6795ee5386706c0b9b19fa54c995beebe9f986612b31f5ab8311afe3be34e614
signer            : loqwapt
signer_fingerprint: b4bf538731a5e9de85fe3a5014052844fe130cb54afab01cd1aaf90f284bd72e
signature         : ibLdu+pbcsnoy1DPJUd7sEOPdcIxzmBTrFb/PzzwyWndc2VVvI9UI33sX3riHA8yxsqvKfegnz3vuGSqhfHHoaOYfFkninw7zn2l0J0AwBzR6n1Elxc9Axrj/ToDL2ZGx0eJYnGRy7omgAQtEjl8e7PU4eRMTtliftpE16hb2elbtcGncmgQ10D/Jsmfwmu+JZXhVGtwDYhWs8ataFn5DD3kBSNrR7vPbsX1L7gY15hDHq9FmOhX8yJdT+ZgHq3oxQ+yR+Opzdmrq5g8C4zL3Fs/r70pbypCXLwyiEYptP0/JxfB+vl8AIjYounw2tc10SsARFl13Nvc+ckii71+5Q==
signature_date    : 2023-07-07T09:46:57.730886
signed_attributes : package,version,architecture,section,priority,name,categories,maintainer,description,depends,conflicts,maturity,locale,target_os,min_wapt_version,sources,installed_size,impacted_process,description_fr,description_pl,description_de,description_es,description_pt,description_it,description_nl,description_ru,audit_schedule,editor,keywords,licence,homepage,package_uuid,valid_from,valid_until,forced_install_on,changelog,min_os_version,max_os_version,icon_sha256sum,signer,signer_fingerprint,signature_date,signed_attributes
General information:
WAPT Server: Debian 11, version 2.4.0.14080, Enterprise Edition
Administration machine: Windows 11, WAPT version 2.4.0.14080
Re: WAPT package for Brave
Published: July 24, 2023 - 2:50 PM
by jpele
Hi Flavien,
Thanks for sharing.
The package had been archived on our end because the binaries in the GitHub repository didn't allow us to package it.
I'm curious to know where you found the download link.
I was able to fix the remove() function; the package will be available on the Store soon :)
. Best regards,
Jimmy
