Installation error following package transfer to a group
Published: July 20, 2023 - 11:29
In the interest of optimization, we have integrated the office suite into a group of common applications.
This update had no impact on the entire fleet, except for one Windows 10 PC on which the office suite uninstalled itself upon rebooting the machine and can no longer be reinstalled.
Since this manipulation, I have a package error line and then a second line (+) which indicates a new installation.
Is it possible to manually delete the entire package installation history to start with a clean installation? Any other solutions?
Here is the error message displayed on the console:
WAPT version: 2.4.0.14080
OS Server: Ubuntu 22.04lts
Operating system of the administration machine: Windows 10
Thank you in advance for your reply.
installing Office 2019
File "C:\Program Files (x86)\wapt\common.py", line 4082, in install_wapt
File "C:\WINDOWS\TEMP\waptxvvldmt5\setup.py", line 26, in install
File "C:\Program Files (x86)\wapt\common.py", line 3859, in run
File "C:\Program Files (x86)\wapt\waptutils.py", line 2118, in run
waptutils.CalledProcessErrorOutput: Command '"setup.exe" /configure "Configuration.xml"' returned non-zero exit status 1603.
Output:
Output:
