Page 1 of 1
[SOLVED] Audit status Warning and unknown
Published: July 24, 2023 - 3:24 PM
by AveyronJJ
Version: WAPTconsole 2.4.0.14031 -1420892a
I'm taking over a WAPT installation and some packages and installations that were done by someone who is no longer with our department.
The last thing they did was install a package that copies an ISO image if one isn't already present.
The package does the copy correctly when necessary, but the audit status remains "Warning" on all machines in the inventory section
and "Unknown" in the General tab.
How can I reset these machines to "OK"?
Have a good day!
Re: Audit status Warning and unknown
Published: July 24, 2023 - 4:27 PM
by dcardon
Hi Jean-Jacques,
could you please provide the contents of your setup.py file so we can see the problem? The return code is returned by the script, so if it's incorrect, we'd need to check the code in the `def install()` function.
The audit status is also handled in the setup.py file, but within the `def audit()` function.
Regards,
Published: July 25, 2023 - 08:14
by AveyronJJ
Hello Denis,
The code is as follows:
import shutil
import os
from datetime import datetime
# Chemin d'accès au fichier ISO dans le paquet WAPT
iso_file_path = os.path.join(os.path.dirname(__file__), 'C6440102C-A.iso')
# Chemin de destination pour la copie de l'ISO
destination_folder = r'C:\PMF\install\cache\office2016'
destination_file_path = os.path.join(destination_folder, 'C6440102C-A.iso')
# Vérification et création du dossier de destination s'il n'existe pas
if not os.path.exists(destination_folder):
os.makedirs(destination_folder)
print(f"{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} - Le dossier de destination a été créé avec succès.")
print(f"{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} - Le dossier existe déjà.")
# Vérification si le fichier ISO existe déjà dans la destination
if not os.path.exists(destination_file_path):
# Copie de l'ISO vers la destination
shutil.copy2(iso_file_path, destination_file_path)
print(f"{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} - La copie de l'ISO s'est bien exécutée.")
print(f"{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} - Le fichier ISO est déjà en place.")
# Chemin du fichier de log
log_file_path = r'C:\PMF\RAPPINST\CopieOffice2016.log'
# Ouverture du fichier de log en mode append (ajout à la fin)
with open(log_file_path, 'a') as log_file:
log_file.write(f"{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} - Copie de Office 2016 : Succès\n")
print(f"{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} - Le fichier de log a été mis à jour avec succès.")
print(f"{datetime.now().strftime('%Y-%m-%d %H:%M:%S')} - Fin du log.")
# Votre code de désinstallation ici
pass
def session_setup():
# Votre code de configuration de session ici
pass
def audit():
# Votre code d'audit ici
pass
def update_package():
# Votre code de mise à jour du package ici
pass
Jean-Jacques
Published: July 25, 2023 - 5:47 PM
by dcardon
Hello Jean-Jacques,
the `def audit()` function is not defined in the package.
By default, WAPT checks for the presence of the software uninstallation key when creating a software deployment package. Since your package doesn't contain any software installation, the `audit()` function is not defined, hence the "UNKNOWN" status. In the main grid, the UNKNOWN audit status is marked as WARNING to draw attention, but we didn't use UNKNOWN because this status is specific to a package (while the others are probably OK).
In the `audit` function, you can add a simple `return "OK"`, or even better, check that the ISO file is present, and if so, return OK; otherwise, return ERROR.
Published: July 26, 2023 - 10:29 AM
by AveyronJJ
Thank you Denis,
have a good day.
Jean-Jacques
