Error code status 2 Teamviewer
Published: August 4, 2023 - 10:12 AM
WAPT 2.4.0 agent workstation under Windows 11
WAPT Console 2.4.0.14058
WAPT server 2.4.0
I'm experiencing problems after updating the TeamViewer package. Many workstations are displaying the following error when I try to deploy it:
This PC has TeamViewer version 15.38.3 installed
I tried to uninstall the package using WAPT, but nothing worked. The only solution is to perform a manual cleanup (delete registry keys, delete the AppData Teamviewer folders, etc.) and then reinstall Teamviewer using WAPT.
Thanks in advance,
Sincerely.
WAPT server 2.4.0
installing tis-teamviewer
Installing: TeamViewer_Setup_fr.exe (15.41.8.0)
File "C:\Program Files (x86)\wapt\common.py", line 4077, in install_wapt
File "C:\WINDOWS\TEMP\wapto0hba4d8\setup.py", line 9, in install
File "C:\Program Files (x86)\wapt\common.py", line 4027, in new_func
return func(*args, **kwargs)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1495, in install_exe_if_needed
run(r'"%s" %s' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)
File "C:\Program Files (x86)\wapt\waptutils.py", line 2115, in run
waptutils.CalledProcessErrorOutput: Command '"TeamViewer_Setup_fr.exe" /S' returned non-zero exit status 2.
Output:
Output:I tried to uninstall the package using WAPT, but nothing worked. The only solution is to perform a manual cleanup (delete registry keys, delete the AppData Teamviewer folders, etc.) and then reinstall Teamviewer using WAPT.
Thanks in advance,
Sincerely.
