Page 1 of 1
[RESOLVED] Security Improvement: RDP Function
Published: October 10, 2023 - 12:27
by stephaneB
in the console, the RDP connection function (right-click -> connect via RDP) uses the machine's IP address.
However, an RDP connection via IP uses the NTLM protocol, which is less secure, and which protected accounts (Active Directory group "Protected Users") are not allowed to use.
Could the Tranquill IT team consider a modification, either to correct this or to allow the user to choose?
In the meantime, we are forced to use our own external tool, which is unfortunate.
Thank you in advance.
Re: Security improvement: RDP function
Published: October 12, 2023 - 6:15 PM
by dcardon
Hi Stéphane,
thanks for your feedback. I've created an internal ticket and this should be fixed in a future version. In the meantime, you can use the "external tools" feature [1] to work around the problem. I'm closing the ticket for now.
Best regards,
[1] https://www.wapt.fr/fr/doc/wapt-console ... pt-console
