[SOLVED] Wapt packet execution error 1619
Published: October 11, 2023 - 1:11 PM
Wapt Enterprise version: 2.4.0.14143
Wapt server: Debian
machine used to create packages: Windows 10
I am currently creating a package for the zedfree software.
My script works perfectly from pyscripter however when I deploy the package from wapt, I get an error "Setup ZEDFREE 2022.4 x64.exe" /S /v/qn\' returned non-zero exit status 1619.
Could you help me understand why I'm only getting this error message on wapt?.
Here is my script:
Here is the error message:
Thank you in advance.
Wapt server: Debian
Here is my script:
import subprocess
name_software= "ZEDFREE"
exe = 'Setup ZEDFREE 2022.4 x64.exe'
silentflags='/S /v/qn'
key=''
min_version='22.4'
command = 'MsiExec.exe /X{00000022-9040-3CA8-8868-36F59DEFD14D} /qn'
# Exécute la commande de désinstallation
subprocess.run(command, shell=True)
print(name_software+" a été désinstallé")
def install_exe():
# installation de l'application
print("L'installation de "+name_software+" commence")
install_exe_if_needed(exe,
silentflags=silentflags,
key=key,
min_version=min_version
print("L'installation de "+name_software+" est terminée")
software_installed = False
for software in installed_softwares(): # boucle for qui vérifie si le logiciel est déjà installé
if software['name'] == name_software:
software_installed = True
if software_installed == True :
uninstall()
install_exe()
break
if software_installed == False :
install_exe()
Installing enit-zedfree-csn(=22.4-2)
L'installation de ZEDFREE commence
Installing: Setup ZEDFREE 2022.4 x64.exe (22.4)
Erreur lors de l'installation de ['enit-zedfree-csn']: erreurs dans les paquets [[PackageRequest(package='enit-zedfree-csn',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('enit-zedfree-csn','22.4-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5192, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4176, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4083, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\wapt3jnfq_t8\\setup.py", line 40, in install\n File "C:\\Windows\\TEMP\\wapt3jnfq_t8\\setup.py", line 20, in install_exe\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4033, in new_func\n return func(*args, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1495, in install_exe_if_needed\n run(r\'"%s" %s\' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2118, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"Setup ZEDFREE 2022.4 x64.exe" /S /v/qn\' returned non-zero exit status 1619.\nOutput:\n']]
File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1910, in run
self.running_task.run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 716, in run
self._run()
File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1288, in _run
Exception: Erreur lors de l'installation de ['enit-zedfree-csn']: erreurs dans les paquets [[PackageRequest(package='enit-zedfree-csn',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('enit-zedfree-csn','22.4-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5192, in install\n result = self.install_wapt(p.localpath,\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4176, in install_wapt\n raise e\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4083, in install_wapt\n exitstatus = setup.install()\n File "C:\\Windows\\TEMP\\wapt3jnfq_t8\\setup.py", line 40, in install\n File "C:\\Windows\\TEMP\\wapt3jnfq_t8\\setup.py", line 20, in install_exe\n File "C:\\Program Files (x86)\\wapt\\common.py", line 4033, in new_func\n return func(*args, **kwargs)\n File "C:\\Program Files (x86)\\wapt\\setuphelpers_windows.py", line 1495, in install_exe_if_needed\n run(r\'"%s" %s\' % (exe, silentflags), accept_returncodes=accept_returncodes, timeout=timeout, pidlist=pidlist)\n File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2118, in run\n raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"Setup ZEDFREE 2022.4 x64.exe" /S /v/qn\' returned non-zero exit status 1619.\nOutput:\n']]
self._run()
