Page 1 of 2
[RESOLVED] GPO agent deployment issue
Published: October 24, 2023 - 08:16
by Christophe
I am on Windows Server 2022 with Wapt version 2.4.014143
I created a GPO that sets up a scheduled task to deploy the WAPT agent to my client workstations.
Everything worked correctly until the upgrade to version 2.4.0.14143 of WAPT.
I modified the hash as usual (--hash=5e80905b087b20818631dcbe765d89a788df2a5140bd55e5413e152d43861fd6 --minversion=2.4.0.14143 --wait=15 --waptsetupurl=http://"IP of my server"/api/v3/get_waptagent_exe/{{ip}}/waptagent.exe)
I tried running the command directly from PowerShell. Here's the error I'm getting:
WAPT version:
WAPT required version: 2.4.0.14143
Wapt agent path: C:\Users\ADMINI~1\AppData\Local\Temp\waptagent.exe
Wget new waptagent from http://172.18.50.13/api/v3/get_waptagent_exe/
Trying to reach http://"IP de mon serveur"/api/v3/get_waptagent_exe/...
Expecting hash sha256: 5e80905b087b20818631dcbe765d89a788df2a5140bd55e5413e152d43861fd6
Using proxy :
Error trying to get http://"IP de mon serveur"/api/v3/get_waptagent_exe/ : Error downloading http://"IP de mon serveur"/api/v3/get_waptagent_exe/: [EHttpSocket] THttpClientSocket.WGet:
 "IP de mon serveur":80/api/v3/get_waptagent_exe/ failed as HTTP Error 404 - Not Found... sleeping
Delete sheduled task "fullwaptupgrade"
c:\temp\waptdeploy.exe : An unhandled exception occurred at $004038EC:
Au caractère C:\Users\Administrateur\Desktop\Pb Wapt.ps1:1 : 1
+ c:\temp\waptdeploy.exe --hash=5e80905b087b20818631dcbe765d89a788df2a5 ...
    + CategoryInfo          : NotSpecified: (An unhandled ex...d at $004038EC::String) [], RemoteException
    + FullyQualifiedErrorId : NativeCommandError
Exception: Error downloading http://"IP de mon serveur"/api/v3/get_waptagent_exe/: [EHttpSocket] THttpClientSocket.WGet: "IP de mon serveur"/api/v3/get_waptagent_exe/ failed as
  $004038EC
  $00404A87
Do you have any idea where the problem comes from?
Re: GPO agent deployment issue
Published: October 24, 2023 - 09:27
by dcardon
Hi Christophe,
have you updated the waptdeploy.exe binary in the GPO to the latest version? We've added support for {{ip}} to allow the use of the remote repository during the initial deployment.
Also, did you restart the postconf after the update?
Regards,
Published: October 24, 2023 - 09:48
by Christophe
Yes, I've updated the Waptdeploy binary.
However, what is postconf?
How do I restart it?
Published: October 25, 2023 - 11:07 AM
by Christophe
Can anyone help me?
I'm using Windows Server 2022, and I'm not sure if I'm affected by postconf.
Published: October 25, 2023 - 11:27
by sfonteneau
In your GPO, have you replaced waptdeploy with the latest version?
It's available on the server:
https://srvwapt.mydomain.lan/wapt/wapta ... deploy.exe
Published: October 25, 2023 - 11:35 AM
by Christophe
Yes, I replaced it correctly.
Published: October 25, 2023 - 11:59 AM
by sfonteneau
Published: October 25, 2023 - 12:12 PM
by Christophe
No, unfortunately.
After accepting the risk because the self-signed certificate isn't secure, I get this message:
Internal Server Error.
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
Published: October 25, 2023 - 1:59 PM
by sfonteneau
Do you have any secondary deposit rules?
Published: October 25, 2023 - 2:15 PM
by Christophe
Yes, indeed, I have rules based on the agents' IP addresses because I have 2 remote repositories
