Page 1 of 1
[SOLVED] Certificate problem
Published: November 16, 2023 - 12:02 PM
by AveyronJJ
- Installed WAPT version (2.4.0.14031)
- Server OS (Linux / CentOS 7)
- Administration/package creation machine OS (Windows 10)
There are currently two of us using a WAPT console (each on a different machine).
When my colleague creates a package, I cannot edit it: see attached message.
If I create a package, he has no problem editing it.
Can you shed some light on this?
Best regards,
Jean-Jacques.
Re: Certificate problem
Published: November 16, 2023 - 9:14 PM
by vcardon
An administrator certificate also serves to define the subset of the network that the administrator manages.
In your case, two people are managing your entire network. Therefore, you will need to deploy your two administrator certificates to all machines in the network.
You can create a WAPT certificate package, deploy it, and your need will be met.
[SOLVED]Re: Certificate problem
Published: November 22, 2023 - 1:32 PM
by AveyronJJ
thank you, I'll look into it.
Have a good day.
