files corrupted, SHA not matching
Published: January 10, 2024 - 09:24
I updated one of my packages by adding a directory to copy to the clients. I had already instructed the package to copy the following directories: sources\PATCH\REVAO
For this update, I added a "CommunLocal" subfolder in sources\PATCH\REVAO, but after sending the new package to the server via the console, I get the following error when installing it on the client machines:
File "C:\Program Files (x86)\wapt\common.py", line 3956, in install_wapt
packagetempdir = entry.unzip_package(cabundle=self.cabundle, target_dir = tempfile.mkdtemp(prefix='wapt',dir=self.wapt_temp_dir))
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2623, in unzip_package
raise e
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2615, in unzip_package
verified_by = self.check_package_signature(cabundle,ignore_missing_files=ignore_missing_files)
File "C:\Program Files (x86)\wapt\waptpackage.py", line 2573, in check_package_signature
raise EWaptCorruptedFiles('Error in package %s in %s, files corrupted, SHA not matching for %s' % (self.asrequirement(), self.sourcespath, errors,))
waptpackage.EWaptCorruptedFiles: Error in package cef-eic-menufed(=6.21.20.1-2) in C:\Windows\TEMP\wapt3kd11709, files corrupted, SHA not matching for ['sources/PATCH/REVAO/CommunLocal/ISAGI', 'sources/PATCH/REVAO/CommunLocal/Manuels', 'sources/PATCH/REVAO/CommunLocal/ModelesExcel']
