[RESOLVED] Session_setup() at each session start
Published: January 22, 2024 - 4:19 PM
As part of package development, we would need code to run every time a session is opened.
We are currently using version 2.4.0141143
Knowing that the execution information for session_setup() is recorded in waptsession.sqlite, we tried to delete this record
But that tells us that the database is already open.
Is there a way to delete this record so that the Session_Setup() code executes again at the next session opening?
Is there another way to do it?
Thanks in advance
def session_setup():
import sqlite3
db_path=makepath(application_data,"wapt","waptsession.sqlite")
con = sqlite3.connect(db_path)
cur = con.cursor()
cur.execute("delete from wapt_sessionsetup where package='bpi-FontsInstaller'")
con.close()
Thanks in advance
