Page 1 of 1
Application rejected connection
Published: February 8, 2024 - 10:25 AM
by galio
I have several posts that seem to change their UUID for no apparent reason.
These machines appear disconnected in the console, and in the server logs I have:
[waptws         ] WARNING Application rejected connection
[waptserver     ] CRITICAL Get_websocket_auth_token failed EWaptAuthenticationFailure('Unknown host UUID RND-2049E68D-A262-4C90-81AB-A1B714BC4BB4. Please register first.')
[waptws         ] WARNING SocketIO connection refused for uuid RND-2049E68D-A262-4C90-81AB-A1B714BC4BB4, sid 347b08d0406c412086dbd199ff6fbf9e: Unknown host RND-2049E68D-A262-4C90-81AB-A1B714BC4BB4, instance
I tried to register a machine and indeed its UUID changed; moreover, the format of this UUID is not the same (prefixed by RND-):
Screenshot from 2024-02-08 10-20-00.png (16.17 KB) Viewed 7713 times
What could be causing this problem? And, more importantly, how can I restore communication with my workstations that are not on-site?
THANKS.
Re: Application rejected connection
Published: February 8, 2024 - 11:34 AM
by sfonteneau
you can upgrade to version 2.5.3 of Wapt, which should resolve this type of problem.
Published: February 8, 2024 - 12:15 PM
by dcardon
Hello Stéphane,
WAPT uses the BIOS UUID returned by WMI by default. If WMI is not responding (because the WMI database is down, or for another reason), a random UUID can be retrieved (starting with RND-*).
We added several extra checks in WAPT 2.5 to address this issue.
Regarding your remote workstations, if the UUID changes, they should try to re-register with the WAPT server, unless you have a reverse proxy handling TLS termination and certificate validation. How did you configure the machine registration?
Best regards,
Published: February 8, 2024 - 1:21 PM
by galio
Hello and thank you for your replies
I understand the RND-* UUIDs better now; I just checked the machine I re-registered, and the BIOS UUID given by WMI does indeed correspond to the old UUID:
C:\Windows\system32>wmic path win32_computersystemproduct get uuid
UUID
4C4C4544-0033-3810-804A-C6C04F565033
I have the same value in the wapt console, so wmi seems to be responding correctly.
There is no reverse proxy but registration requires authentication, that's why clients do not re-register.
I was looking at the logs to make sure everything was okay before doing the 2.5 update; if it helps to solve the problem, I'll do it quickly.
However, I don't see how to re-establish communication with the still-erroneous workstations. Will clients on version 2.4 change the UUID again if they manage to read the WMI database?
Sincerely
