Thank you for your help. I can only find the setup.py file in the WAPT\WAPTUPGRADE folder.
I don't have any files with that name directly in the WAPT directory
I'm attaching an image of the py files located in my wapt folder
I'm including the contents of the setup.py file because I can't paste it as an attachment
Knpc
- contents of the wapt folder
- File extension py.JPG (43.89 KB) Viewed 10041 times
SETUP.PY FILE
import from setuphelpers *
import os
import _winreg
import tempfile
import shutil
# registry key(s) where WAPT will find how to remove the application(s)
def update_sources():
files = [
'common.py',
'setuphelpers.py',
'wapt-get.exe',
'wapt-get.exe.manifest',
'wapt-get.py',
'waptdevutils.py',
'waptpackage.py',
'windnsquery.py',
'wapttray.exe',
'waptexit.exe',
'keyfinder.py',
'COPYING.txt',
'templates',
'waptconsole.exe',
'waptconsole.exe.manifest',
'waptservice',
'languages',
r'lib\site-packages\babel\__init__.py',
r'lib\site-packages\babel\_compat.py',
r'lib\site-packages\babel\core.py',
r'lib\site-packages\babel\global.dat',
r'lib\site-packages\babel\localtime',
r'lib\site-packages\babel\plural.py',
r'lib\site-packages\babel\localedata\en.dat',
r'lib\site-packages\babel\localedata\fr.dat',
r'lib\site-packages\babel\messages',
r'lib\site-packages\babel\support.py',
r'lib\site-packages\babel\compat.py',
r'lib\site-packages\babel\dates.py',
r'lib\site-packages\babel\localedata.py',
r'lib\site-packages\babel\numbers.py',
r'lib\site-packages\babel\util.py',
r'lib\site-packages\flask_babel',
r'lib\site-packages\pytz',
r'lib\site-packages\speaklater',
r'lib\site-packages\requests_kerberos_sspi',
r'lib\site-packages\lib\site-packages\flask_kerberos_sspi.py',
r'lib\site-packages\kerberos_sspi.py',
r'lib\site-packages\wapt.pth',
def ignore(src,names):
result = []
for name in names:
for pattern in ['*.pyc','*.exe']:
if glob.fnmatch.fnmatch(name,pattern):
result.append(name)
return result
checkout_dir = os.path.abspath(os.path.join(os.getcwd(),'..'))
# cleanup patches dir
if os.path.exists(os.path.join(checkout_dir,'waptupgrade','patches')):
shutil.rmtree(os.path.join(checkout_dir,'waptupgrade','patches'))
os.makedirs(os.path.join(checkout_dir,'waptupgrade','patches'))
for f in files:
fn = os.path.join(checkout_dir,f)
target_fn = os.path.join(checkout_dir,'waptupgrade','patches',f)
if os.path.isfile(fn):
if not os.path.exists(os.path.dirname(target_fn)):
os.makedirs(os.path.dirname(target_fn))
filecopyto(fn,target_fn)
elif os.path.isdir(fn):
copytree2(
src=fn,
dst=target_fn,
onreplace = default_overwrite,
ignore=ignore)
return True
def update_control(entry):
"""Update package control file before build-upload"""
if update_sources():
waptget = get_file_properties(r'patches\wapt-get.exe')
rev = open('../version').read().strip()
entry.package = '%s-waptupgrade' % WAPT.config.get('global','default_package_prefix')
entry.version = '%s-%s' % (waptget['FileVersion'],rev)
print(u'Keeping current control data %s (%s)'%(control.package,control.version))
def update_registry_version(version):
# updatethe registry
with _winreg.CreateKeyEx(HKEY_LOCAL_MACHINE,r'SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\WAPT_is1',\
0, _winreg.KEY_READ| _winreg.KEY_WRITE ) as waptis:
reg_setvalue(waptis,"DisplayName","WAPT %s" % version)
reg_setvalue(waptis,"DisplayVersion","WAPT %s" % version)
reg_setvalue(waptis,"InstallDate",currentdate())
def copytree2(src, dst, ignore=None, onreplace=default_skip, oncopy=default_oncopy, enable_replace_at_reboot=True, onerror=None):
"""Copy src directory to dst directory. dst is created if it doesn't exist
src can be relative to installation temporary dir
oncopy is called for each file copy. if False is returned, copy is skipped
onreplace is called when a file will be overwritten.
logger.debug('Copy tree from "%s" to "%s"' % (ensure_unicode(src),ensure_unicode(dst)))
# path relative to temp directory...
tempdir = os.getcwd()
if not os.path.isdir(src) and os.path.isdir(os.path.join(tempdir,src)):
src = os.path.join(tempdir,src)
names = os.listdir(src)
if callable(ignore) and ignore is not None:
ignored_names = ignore(src, names)
ignored_names = set()
if not os.path.isdir(dst):
if oncopy('create directory',src,dst):
os.makedirs(dst)
errors = []
for name in names:
if name in ignored_names:
continues
srcname = os.path.join(src, name)
dstname = os.path.join(dst, name)
try:
if os.path.isdir(srcname):
if oncopy('directory',srcname,dstname):
copytree2(srcname, dstname, ignore = ignore, onreplace=onreplace, oncopy=oncopy)
if os.path.isfile(dstname):
if onreplace(srcname,dstname) and oncopy('overwrites',srcname,dstname):
os.unlink(dstname)
shutil.copy2(srcname, dstname)
if oncopy('copy',srcname,dstname):
except (IOError, os.error) as why:
#print(u'IO Error copying from "%s" to "%s": %s' % (ensure_unicode(src),ensure_unicode(dst),ensure_unicode(why)))
if onerror is not None and callable(onerror):
try:
onerror(srcname,dstname,why)
except Exception as e:
errors.append((srcname,dstname,ensure_unicode(e)))
errors.append((srcname,dstname,ensure_unicode(why)))
# catch the Error from the recursive copytree so that we can
# continue with other files
except shutil.Error as err:
logger.critical(u'shutil Error copying from "%s" to "%s": %s' % (ensure_unicode(srcname),ensure_unicode(dstname),ensure_unicode(err)))
errors.extend(err.args[0])
try:
shutil.copystat(src, dst)
Except for OSError, why?
if WindowsError is not None and isinstance(why, WindowsError):
# Copying file access times may fail on Windows
pass
print(u'Error copying stats from "%s" to "%s": %s' % (ensure_unicode(src),ensure_unicode(dst),ensure_unicode(why)))
errors.append((src, dst, str(why)))
if errors:
raise shutil.Error, errors
def add_at_cmd(cmd,delay=1):
import datetime
at_time = (datetime.datetime.now() + datetime.timedelta(minutes=delay)).strftime('%H:%M:%S')
print(run('at %s "%s"'%(at_time,cmd)))
# if you want to modify the keys depending on environment (win32/win64... params..)
print(u'Partial upgrade of WAPT client')
killalltasks('wapttray.exe')
killalltasks('waptconsole.exe')
def onerror(srcname,dstname,e):
print u"Error %s %s %s" %(srcname,dstname,ensure_unicode(e))
if e[0] == 5: # locked
filecopyto(srcname,dstname+'.pending')
replace_at_next_reboot(None, dstname)
raise e
def check_exe_version(src,dst):
if os.path.splitext(dst)[1] in ('.exe','.dll'):
try:
ov = get_file_properties(dst)['FileVersion']
nv = get_file_properties(src)['FileVersion']
return Version(ov)
except:
return True
return True
copytree2('patches',WAPT.wapt_base_dir,
onreplace = check_exe_version,
onerror = onerror)
update_registry_version(control.version)
# restart of service cannot be done by service...
if service_installed('waptservice') and service_is_running('waptservice'):
import requests,json
try:
res = json.loads(requests.get('
http://127.0.0.1:8088/waptservicerestart.json').text)
except:
tmp_bat = tempfile.NamedTemporaryFile(prefix='waptrestart',suffix='.cmd',mode='wt',delete=False)
tmp_bat.write('net stop waptservice\n')
tmp_bat.write('net start waptservice\n')
tmp_bat.write('del "%s"\n'%tmp_bat.name)
tmp_bat.close()
add_at_cmd(tmp_bat.name)
print(u'Upgrade done')
