problem creating a package
Published: November 24, 2015 - 7:12 PM
I'm testing WAPT to see if it meets our needs.
I am at the stage of configuring the environment in order to create a package.
I need to install the tis-waptdev.wapt package, but here's the error I'm getting:
If I try to import tis-waptdev from the tranquil.it repository, it asks me if I want to duplicate the file. I answer yes, then I get the message "Download canceled: "is an invalid integer"
I can't find a solution given my current skill level!
Thanks in advance for the help
Fabien.
C:\Windows\system32>wapt-get install C:\Users\test\Downloads\tis-waptdev.wapt
Installing WAPT file C:\Users\test\Downloads\tis-waptdev.wapt
FATAL ERROR : Exception: Package file C:\Users\test\Downloads\tis-waptdev.wa
pt signature is invalid
Fabien.
