[SOLVED] tis-enable-bitlocker: does not recognize uefi
Published: April 30, 2024 - 11:00 AM
Good morning
I don't understand where the following problem comes from:
On several machines, the packet failed with the following message:
In the code, I see that it is the Get-ComputerInfo command that is used when searching for the "BiosFirmwareType" property (with uppercase pass).
On these PCs, I enter Get-ComputerInfo and the property is indeed "Uefi".
So, I don't understand, it seems the package isn't retrieving the property...
Any ideas?
File "C:\WINDOWS\TEMP\waptry_hdetw\setup.py", line 72, in install
File "C:\Program Files (x86)\wapt\waptutils.py", line 1957, in error
waptutils.EWaptSetupException: Fatal error : ERROR: This computer BIOS does not boot in UEFI mode, you have to change BIOS mode to continue
Any ideas?
