Page 1 of 1
[SOLVED] tis-zulip installation problem
Published: May 13, 2024 - 3:43 PM
by lerti/wb
I recently tried to import the new tis-zulip package and deploy it to the machines.
The problem is, if I install the package locally using VS Code, there are no issues, but when I deploy it to remote machines via the WAPT console, it doesn't appear as an installed program in Windows (no errors in the logs, but no shortcut created, and it clearly hasn't installed, although I can find it in the machine's software inventory in the WAPT console). I should mention that I previously had a custom zulip package that I decided to replace with the one provided by Tranquil.it.
WAPT Discovery version 2.4.0.14143, server running Linux, clients running Windows 10.
If you have any ideas, thank you.
Re: tis-zulip installation problem
Published: May 13, 2024 - 6:33 PM
by sfonteneau
Oops, thanks for the info, I just fixed the package; the "ALLUSERS":1 was missing.
The package will be available in wapt-testing in a few minutes.
Published: May 14, 2024 - 08:36
by lerti/wb
It works much better, thank you!
Re: [SOLVED] tis-zulip installation problem
Published: May 14, 2024 - 09:09
by dcardon
Hello William,
thank you for your feedback. :-)
Please don't hesitate to report any problems you may encounter with packages from the store. :-)
