Page 1 of 1
[SOLVED] Configuration def session-setup
Published: May 24, 2024 - 11:58 AM
by Emmanuel64
Good morning
I added a "session-setup" parameter to a package:
def session_setup():
filecopyto('v6-gpo-configuration.json',makepath(user_local_appdata(),'UpSignOn'))
When I'm on the DEV console and I run "session-setup" directly, the file transfers correctly. But during package installation, it doesn't work. I tried "wapt-get session-setup -f hasp-UpSignOn", but there was no change
Do you have any idea what my mistake might be?
THANKS
Re: Configuration def session-setup
Published: May 28, 2024 - 08:02
by gaelds
I asked pretty much the same question in 2017
Simon's answer is here:
viewtopic.php?t=595
Published: May 28, 2024 - 08:52
by Emmanuel64
Thanks gaelds.
I had searched for the answer on the forum, but hadn't managed to find it.
Have a good day.
Published: May 30, 2024 - 08:27
by Emmanuel64
Good morning
To close this ticket, and for those who will be looking for an answer
Simon therefore confirms that:
With session_setup, it is not possible to call files contained in the package.
They will need to be copied into a directory beforehand.
For example, in my case:
if not isdir(makepath(user_local_appdata,'UpSignOn')):
mkdirs(makepath(user_local_appdata,'UpSignOn'))
filecopyto('C:/Windows/System32/v6-gpo-configuration.json',makepath(user_local_appdata(),'UpSignOn'))
# Declaring local variables
# Installing the software
print("Installing: UpSignOn-7.7.1-silent-installer.msi")
install_msi_if_needed('UpSignOn-7.7.1-silent-installer.msi' , key = '' , min_version = "7.7.1" )
filecopyto('v6-gpo-configuration.json',makepath(system32))
The file will therefore be copied from the local disk to c:/user/xxx/appdata/local/UpSignOn the next time the user logs in
Thanks to gaelds for redirecting me
