Page 1 of 1
[SOLVED] nginx problem
Published: June 5, 2024 - 10:26
by kbrozi
I had to reinstall the WAPT server, but I'm encountering a problem when I try to install an agent: the nginx service is not found.
Can you help me?
Thank you.
Re: nginx
Published: June 5, 2024 - 10:58 AM
by kbrozi
I just noticed that I can no longer connect to the WAPT server from the console
Re: nginx
Published: June 5, 2024 - 11:26
by sfonteneau
Could you try running this?:
c:\wapt\waptpython.exe c:\wapt\waptserver\winsetup.py -ldebug install_nginx -cc:\wapt\conf\waptserver.ini
then restart the server
Re: nginx
Published: June 5, 2024 - 2:01 PM
by kbrozi
After installing Nginx and restarting the WAPT service, I also restarted the VM, but it still doesn't work.
Re: nginx
Published: June 5, 2024 - 2:16 PM
by sfonteneau
Do you have anything in:
C:\Program Files (x86)\wapt\waptservice\nginx\conf?
or in
C:\wapt\waptservice\nginx\conf
Re: nginx
Published: June 5, 2024 - 2:26 PM
by kbrozi
Here's what I have in the configuration:
Re: nginx
Published: June 6, 2024 - 8:46 AM
by kbrozi
In wapt service I don't have nginx:
Re: nginx
Published: June 6, 2024 - 10:04 AM
by sfonteneau
Contact our support team directly by phone.
Your nginx configuration appears to be incorrect even after restarting the service installation.
Re: nginx
Published: June 6, 2024 - 11:42 AM
by sfonteneau
Seen over the phone.
It's normal that the Waptagent doesn't exist on a new installation. The procedure is therefore the same as for a fresh install.
However, the server was reinstalled, and the old HTTPS certificate was lost (and not backed up).
We therefore regenerated a correct Waptagent. It will then need to be redeployed across the network via Group Policy.
