[RESOLVED] WUA Inaccessible from the console
Published: June 12, 2024 - 06:23
Following the update to 2.5.5.15602, I can no longer access Windows updates.
- My license is well recognized.
- I still have the package that allows me to install the updates
- In the WAPT agent generation or dynamic modification settings, I don't see any options related to this
- In the display preferences, "Enable WAPTWUA features" is greyed out.
I tried adding that to waptconsole.ini
And also in the wapt-get.ini file
Was there a change in the configuration that I missed?
Sincerely
[waptwua]
enabled=True
default_allow=False
direct_download=False
download_scheduling=7d
install_at_shutdown=True
install_scheduling=12h
install_delay=3d
Sincerely
