Page 1 of 1
[SOLVED] Problem with the get_file_association() function
Published: June 24, 2024 - 3:10 PM
by bgallois
I am contacting you because I have just noticed a problem with my infrastructure which no longer seems to recognize the get_file_association() function of the setuphelpers_windows.py library.
I noticed this problem because the OpenOffice 4.1.15 package refuses to install with the following error:
Ligne de Commande : install "C:\waptdev\odlb-openoffice_4.1.15-21_windows_6.1_DEV_fr-wapt\WAPT\.."
Installing WAPT files C:\waptdev\odlb-openoffice_4.1.15-21_windows_6.1_DEV_fr-wapt
2024-06-24 13:20:36,704 CRITICAL Fatal error in install script: NameError: name 'get_file_assocation' is not defined:
  File "C:\waptdev\odlb-openoffice_4.1.15-21_windows_6.1_DEV_fr-wapt\setup.py", line 57, in install
    if get_file_assocation(".doc") is not None and get_file_assocation(".docx") is not None:
FATAL ERROR : NameError: name 'get_file_assocation' is not defined
Exit code:  3
I haven't found a solution. Seeing that there was an update to version 2.5.5, I thought, with a bit of luck, that would solve my problem ;)
The update went well, but the problem persists.
I think the problem will arise with other packages like LibreOffice. It's surprising; I haven't been informed of any problems with it.
So I look at how the libreoffice-fresh 7.6.4 package is formed and I see that it includes the declaration of the get_file_association() function, so the problem does not arise.
However, I can clearly see the get_file_association() function in the setuphelpers_windows.py file, I don't understand why it is not/no longer recognized.
I can work around the problem by adding the function to the openoffice package like libreoffice does, but maybe there's a problem higher up, right?
Do you have any idea?
Thanks in advance.
Baptiste
Re: [Problem] with the get_file_association() function
Published: June 25, 2024 - 09:26
by sfonteneau
thank you for your feedback.
Indeed, in the new version of WAPT, we corrected the name of a function:
get_file_association -> get_file_association.
The packages have been corrected accordingly, but we had forgotten OpenOffice.
I have corrected the package; it is already on the store.
Published: June 25, 2024 - 09:33
by bgallois
okay, I didn't see the change either and I didn't understand where the problem was coming from.
Thank you very much for your feedback as well. ;-)
You can close the topic, ;-)
Baptiste.
