[SOLVED] Create_shortcut() function with a URL
Published: July 23, 2024 - 3:39 PM
Good morning
I'm trying to create shortcuts to web addresses using the create_shortcut() function, but it returns an error. Does the function only work with local targets?
Here is the message:
How can I generate a shortcut to a web address?
Sincerely
Tom
2024-07-23 15:32:26,424 CRITICAL Fatal error in install script: 0x80070057 : Paramètre incorrect.:
File "c:\waptdev\La_Normandise_2024.7.16-1_x64_PROD_fr-wapt\setup.py", line 73, in install
create_shortcut(icopath,target=icotarget)
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3983, in create_shortcut
winshell.CreateShortcut(path, target, arguments, wDir, (icon, 0), '')
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 887, in CreateShortcut
lnk = shortcut (Target)
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 507, in shortcut
return Shortcut.from_target (source)
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 414, in from_target
return cls (
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 391, in __init__
setattr (self, k, v)
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 456, in _set_path
self._shell_link.SetPath (path)
pywintypes.com_error: (-2147024809, 'Paramètre incorrect.', None, None)
FATAL ERROR : 0x80070057 : Paramètre incorrect.
Exit code: 3
Sincerely
Tom
