Windows restarts every 10-15 minutes
Published: October 3, 2024 - 4:50 PM
I'm starting this thread because we're facing a problem that, for the moment, seems inexplicable.
We have a WAPT server, version 2.5.5.15591, with the agents running the same version.
When the machines are no longer communicating with the domain (remote work without a VPN), they restart every 10-15 minutes.
The diagnostics that lead us to believe there's a link with WAPT are as follows:
We created a clean machine, which, when in the same state (no domain connection), works perfectly.
As soon as WAPT is installed on it, it restarts after 10-15 minutes. If we remove WAPT, the machine works normally again.
We also tested removing the machine from the domain, with WAPT installed, and it works even when it's outside the domain.
If the machine is in the domain, but has no internet access (no access to the WAPT Web repository), it doesn't restart either.
The problem seems to be the following: When the workstation, with WAPT installed, is in the domain but can no longer communicate with it, it restarts every 10-15 minutes.
For your information, the domain is a Synology DSM 7.2-64570 Active Directory with a 2008 R2 forest version.
Have you ever encountered this type of problem? Any ideas?
