Page 1 of 1
[SOLVED] Parse XML on BeautifulSoup
Published: October 16, 2024 - 3:38 PM
by jmorillo
I need to create a "Clari Copilot" package (easy, their installer.exe works correctly with /S).
However, I'm stuck on the update_package.py function because the binary is hosted on a CDN, without a main HTML page, but I was able to find an XML page listing the releases.
In setupdevhelpers.py, there are the bs_find and bs_find_all functions (which call BeautifulSoup (bs4)) with features="html.parser" by default.
BeautifulSoup, as well as the bs_find* functions, accept feature="xml", except that BeautifulSoup needs the "lxml" Python library, which isn't present by default in WAPT's Python virtual environment, I believe.
I could create a crude parser using a workaround, but it would be better to use bs_find* and BeautifulSoup natively with XML.
Do you have any suggestions? Is there a plan to integrate this LXML library into a future release? Or perhaps I've missed something?...
Thank you very much in advance.
Jordi
Re: Parser XML on BeautifulSoup
Published: October 16, 2024 - 4:45 PM
by blemoigne
Hi Jordi,
You can still parse the XML with the HTML parser (you'll get a warning). This is the case with this package: https://wapt.tranquil.it/store/fr/tis-0install
Published: October 16, 2024 - 6:33 PM
by jmorillo
Thank you so much, Bertrand!
Everything is working correctly!
Just a minor issue because the XML element was declared like this: "<Key> "
I couldn't find any results for
bs_find_all('https://contoso.com/test.xml', 'Key')
You had to put Key -> key (lowercase) in
bs_find_all('https://contoso.com/test.xml', 'key')
for a result to be displayed.
In any case, I will be able to finish the update_package function.
Thank you again so much
Published: October 17, 2024 - 3:47 PM
by dcardon
Hi Jordi,
thanks for your feedback, :-)
I'm marking the topic as resolved.
