Page 1 of 1
[SOLVED] Photofiltre software installation and directory permission issues
Published: October 22, 2024 - 1:46 PM
by Olivier Schmitt
Hello everyone,
package
(https://wapt.tranquil.it/store/fr/tis-photofiltre
) on a few machines here, and it seems the installer isn't correctly applying the standard permissions to the Program Files (x86) directory.
Can anyone confirm this bug?
If not, would it be possible to simply add `icacls "C:\Program Files (x86)\Photofiltre7" /grant users:(RX) /T` to the setup.py file?
Thanks in advance for any feedback.
Re: PhotoFiltre software installation and directory permission problems
Published: October 22, 2024 - 2:44 PM
by jlepiquet
Thank you for reporting this. Indeed, there is an issue with permission propagation for users.
I have just created the iCalcs update and pushed it.
The new version of the application will be available in the store within a few days.
Published: October 24, 2024 - 3:14 PM
by Olivier Schmitt
I'm taking this opportunity to let you know that the software is installed in English.
Unfortunately, I can't find the French language pack on their official website to deploy it separately.
I don't know your language priority requirements on the store, but it might be helpful to add either the French language pack or the language pack itself?
Published: October 28, 2024 - 4:16 PM
by jlepiquet
I just looked into it, we're going to modify the package so that it installs in French by default and to add additional language packs.
Thanks for the feedback.
Published: November 25, 2024 - 11:36 AM
by dcardon
Hi Olivier,
sorry for the delay. The package had been fixed internally but not yet pushed to the store. It was pushed this morning and is already available on wapt-testing and will be available on the store in the coming days:
https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
I'm marking this topic as resolved.
Regards,
