Page 1 of 1
Using the disallowrun registry in session_setup
Published: November 6, 2024 - 3:47 PM
by guigeek
Server:
Version: 2.5.5.15697
OS: Debian 12.7
Client:
Windows 11 23H2
I would like to block specific executables based on the user account.
To do this, I would like to use the command
`registry_setstring(HKEY_CURRENT_USER, "SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Policies\\Explorer\\DisallowRun", '1', 'powershell.exe', type=REG_SZ)`
to block PowerShell, for example.
However, I get a PermissionError: [WinError 5] Access is denied. The user cannot write to this registry.
Is there a way to work around this and successfully set this registry?
Thank you for your help.
Have a good day.
Re: Using registry disallowrun in session_setup
Published: November 7, 2024 - 9:15 AM
by jacky35
Published: November 7, 2024 - 9:50 AM
by dcardon
Hello guigeek,
what we see in the HKCU user registry with regedit is a mount of the NTUSER.dat and UsrClass.dat databases, as well as Appx-specific parts and parts related to the user GPO.
In this case, the key you want to change, SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Policies, is part of the user GPOs, if I'm not mistaken, and therefore cannot be modified by the user.
You can try the LGPO tool to define a local GPO that makes the change in question.
@Jacky, it must have been launched in session_setup if the access rights are incorrect ;-)
. Regards,
