Page 1 of 2
Problem executing post-conf on RHEL 8.8
Published: November 18, 2024 - 2:30 PM
by silica
I am following the documentation below: https://www.wapt.fr/fr/doc-2.5/wapt-ser ... er-install
And I'm encountering a problem running the post-installation on RHEL 8.8:
[user@srvwapt ~]$ sudo /opt/wapt/waptserver/scripts/postconf.sh --cspn-toe
Waptserver
    Version: 2.5.5.15697-20422a0b
  File "/opt/wapt/waptserver/scripts/postconf.py", line 1316, in <module>
    main()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 885, in main
    ensure_postgresql_db(db_name=server_config['db_name'], db_owner=server_config['db_name'], db_password=server_config['db_password'])
  File "/opt/wapt/waptserver/scripts/postconf.py", line 592, in ensure_postgresql_db
    migrate_db_if_needed()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 514, in migrate_db_if_needed
    if get_current_running_postgresql_version() < Version('10'):
  File "/opt/wapt/waptserver/scripts/postconf.py", line 71, in get_current_running_postgresql_version
    version = run("sudo -iu postgres psql -t -c 'SHOW server_version;'").split('(',1)[0].strip()
  File "/opt/wapt/waptutils.py", line 2177, in run
waptutils.CalledProcessErrorOutput: Command b"sudo -iu postgres psql -t -c 'SHOW server_version;'" returned non-zero exit status 126.
Output:/etc/profile: line 31: /usr/bin/id: Permission denied
/etc/profile.d/colorgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied
/etc/profile.d/colorxzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied
/etc/profile.d/colorzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied   ┌────────────────────────────┐
/etc/profile.d/lang.sh: line 11: /usr/bin/sed: Permission denied                                      │ SELinux correctly          │
/etc/profile.d/which2.sh: line 4: /bin/readlink: Permission denied                                    │ configured for Nginx       │
/etc/profile.d/which2.sh: line 4: /bin/basename: Permission denied                                    │ reverse proxy              │
/etc/profile: line 31: /usr/bin/id: Permission denied                                                 │                            │
/etc/profile.d/colorgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied    │                            │
/etc/profile.d/colorxzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied  ├────────────────────────────┤
/etc/profile.d/colorzgrep.sh: /usr/libexec/grepconf.sh: /bin/sh: bad interpreter: Permission denied   │         <  OK  >           │
/etc/profile.d/lang.sh: line 11: /usr/bin/sed: Permission denied                                      └────────────────────────────┘
-bash: /bin/psql: Permission denied
However, when I manually execute the problematic command, I get the following:
[user@srvwapt ~]$ sudo -iu postgres psql -t -c 'SHOW server_version;'
 10.23
Could you enlighten me?
Thank you in advance
Re: Problem executing post-conf on RHEL 8.8
Published: November 19, 2024 - 1:45 PM
by sfonteneau
I'm not certain, but I believe this problem sometimes occurs when using `sudo` within another `sudo` command.
Try launching `postconf` directly as root without sudo privileges?
Published: November 19, 2024 - 2:38 PM
by silica
Thank you for your reply, I hadn't thought of that.
Unfortunately, I have the same problem when launching the post-configuration directly as root without sudo :( :
[root@srvwapt /]# /opt/wapt/waptserver/scripts/postconf.sh --cspn-toe
Waptserver
    main()
Published: November 19, 2024 - 3:05 PM
by sfonteneau
In your case, it's the command:
That doesn't work in your case. Can you launch it manually?
Published: November 19, 2024 - 3:19 PM
by silica
Effectively.
As stated in my initial post, when I launch it manually (as a user), it returns:
[user@srvwapt /]$ sudo -iu postgres psql -t -c 'SHOW server_version;'
 10.23
But the post-conference approach doesn't work either.
I just tried it as root (but leaving "sudo" as in the script):
[root@srvwapt /]# sudo -iu postgres psql -t -c 'SHOW server_version;'
/etc/profile.d/colorls.sh: line 26: /usr/bin/tty: Permission denied
This test leads me to try launching the post-configuration as a user without sudo (since there are sudo commands in the script), and I get a different error:
[user@srvwapt /]$ /opt/wapt/waptserver/scripts/postconf.sh --cspn-toe
Waptserver
    main()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 858, in main
    selinux_rules()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 126, in selinux_rules
    run('setsebool -P httpd_can_network_connect 1')
waptutils.CalledProcessErrorOutput: Command b'setsebool -P httpd_can_network_connect 1' returned non-zero exit status 255.
Output:Cannot set persistent booleans, please try as root.
Published: November 19, 2024 - 3:31 PM
by dcardon
Hi Kevin,
in your first message, it seems you have a very restrictive SELinux configuration. Do you have a public SELinux profile so we can apply it and see how to handle this scenario?
Regarding your last problem, you can add `sudo` before `setsebool`; this is precisely to add some SELinux configuration between the waptserver service and the nginx server.
Regards,
Published: November 19, 2024 - 4:29 PM
by silica
I'm using RHEL 8.8 with a post-installation mandated by my organization's security department. It's possible there are some rather restrictive configurations.
My SELinux skills are limited; is this a result of the command? export week Who are you interested in?
Regarding your last suggestion, I added `sudo` before the two `setsebool` commands in postconf.py
def selinux_rules():
    """ SELinux httpd security rules """
    run('sudo setsebool -P httpd_can_network_connect 1')
    run('sudo setsebool -P httpd_setrlimit on')
    for sepath in ('wapt', 'wapt-host', 'waptwua','wads'):
        try:
            run('semanage fcontext -a -t httpd_sys_content_t "/var/www/html/%s(/.*)?"' % sepath)
        except:
            pass
        run('restorecon -R -v /var/www/html/%s' % sepath)
But the result is no better :(
Waptserver
    main()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 598, in ensure_postgresql_db
    run('systemctl start %s' % PGSQL_SVC)
waptutils.CalledProcessErrorOutput: Command b'systemctl start postgresql' returned non-zero exit status 1.
Output:Failed to start postgresql.service: Interactive authentication required.
See system logs and 'systemctl status postgresql.service' for details.
Published: November 19, 2024 - 5:46 PM
by dcardon
Hi Kevin,
it seems your user doesn't have the necessary permissions to restart the systemd service. You can also add `sudo` before it.
Published: November 20, 2024 - 12:29 PM
by silica
I added a sudo in front of all systemctl commands.
We're making progress, but I'm now stuck at this step... my user doesn't have write access to the PostgreSQL configuration file:
[user@srvwapt ~]$ /opt/wapt/waptserver/scripts/postconf.sh --cspn-toe
[*] postgresql - we suppose that the db does not exist either (or the installation has been screwed up)
[*] postgresql - creating db wapt
[ ] postgresql jsquery extension is not available. This is not mandatory. Check if a package like postgresql-11-jsquery is available for your distribution
Upgrading DB structure.
[*] postgresql changing max_connections parameter in postgres config file /var/lib/pgsql/data/postgresql.conf
Waptserver
    main()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 889, in main
    configure_max_connections()
  File "/opt/wapt/waptserver/scripts/postconf.py", line 716, in configure_max_connections
    with open(config_file_path, "r+") as config_file:
PermissionError: [Errno 13] Permission denied: '/var/lib/pgsql/data/postgresql.conf'
Published: November 27, 2024 - 12:24 PM
by silica
do you have any ideas on how to resolve this situation?
Should I contact Wapt Support?
Regards
