Page 1 of 1
[RESOLVED] Package for MediaInfo
Published: November 26, 2024 - 2:09 PM
by bastien30
Here is a package I made for the MediaInfo software (https://mediaarea.net/fr/MediaInfo), compatible with 32/64-bit:
from setupdevhelpers import *
    appver = control.get_software_version()
    install_exe_if_needed(glob.glob("MediaInfo_GUI*.exe")[0],
        silentflags='/S',
        key='MediaInfo',
        min_version=appver
def update_package():
    url = r'https://mediaarea.net/fr/MediaInfo/Download/Windows'
    for releases in bs_find_all(url, r'a'):
        if not r'Universal (32/64 bit)' in releases.text :
            continue
            url_dl = r'https:%s' % releases[r'href']
            break
    latest_bin = url_dl.split(r'/')[-1]
    latest_version = url_dl.split(r'/')[-1].split(r'_')[-2]
    print(r'Latest version is %s' % latest_version)
    if Version(latest_version) > Version(appver):
        print(r'Downloading latest binary %s ...' % latest_bin)
        wget(url_dl, latest_bin)
        control.version = '%s-%s'%(latest_version, control.version.split('-')[-1])
        print('Changing version to: %s in WAPT\\control' % control.version)
        remove_outdated_binaries(latest_version)
        print("Already up to date")
If it can be of use to others :D
Re: [RESOLVED] Package for MediaInfo
Published: November 28, 2024 - 1:46 PM
by fschelfaut
thank you so much for sharing the code! My colleague Ingrid took care of the package, and we added it on our end.
It will be available on the official store in 5 days. In the meantime, you can find it on the testing repository here
, Flavien.
Published: November 28, 2024 - 2:01 PM
by bastien30
Awesome, thank you! :D
