Page 1 of 1
[RESOLVED] Webview Error
Published: November 27, 2024 - 09:25
by jorico
I saw that a fix for Webview had been deployed, however even with version 131.0.2903.63-11
I'm still having an installation problem:
  File "C:\WINDOWS\TEMP\waptmg37rtu9\setup.py", line 15, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3991, in run
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2177, in run
waptutils.CalledProcessErrorOutput: Command 'MicrosoftEdgeWebView2RuntimeInstallerX64.exe /silent /install' returned non-zero exit status 2147748109.
Output:
Re: Webview Error
Published: November 28, 2024 - 9:50 AM
by PaulSLA
I have the exact same issue here. It was fixed by the patch. But with version 131.0.2903.63-11, the problem has returned.
  File "C:\Windows\TEMP\wapt5kn4nu01\setup.py", line 15, in install
Output:
Output:
Sincerely
Re: Webview Error
Published: November 28, 2024 - 11:18 AM
by jlepiquet
If you have an Enterprise account, a new version of the package is available for testing here:
The error code you are receiving corresponds to an attempt to downgrade the application.
We have added conditions to prevent an installation attempt if a higher or equal version is already present on the
x64 machine: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
and
x86 machine: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Published: November 29, 2024 - 7:48 AM
by jorico
I just tested the new package and it works perfectly.
Thank you very much. :D
Re: Webview Error
Published: November 29, 2024 - 09:12
by jlepiquet
Hi Johan,
Glad it's working.
I'm marking the topic as Resolved.
Best regards,
