[SOLVED] MS Edge: It's still not working!
Published: Dec 20, 2024 - 10:55 AM
Good morning
Since you implemented scheduled task management in the MS Edge package, I have been getting installation errors all the time.
Example with the most recent one (131.0.2903.112-46):
With each new package, I am forced to remove the two blocks (before and after installation) that manage this.
I am counting on you to correct this flawed management
Tom
Installing: MicrosoftEdgeEnterpriseX64.msi (131.0.2903.112)
Waiting for key: {D8A6BB3B-CDD1-3B3E-B1CB-89329C55D211} to appear in Windows registry
File "C:\Program Files (x86)\wapt\common.py", line 4294, in install_wapt
File "C:\Windows\TEMP\wapt3km0znqs\setup.py", line 86, in install
TypeError: string indices must be integers
Tom
