Page 1 of 1
[RESOLVED] 502 socket.io error after updating to 2.6
Published: Dec 30, 2024 - 10:15
by impulse
Hello everyone,
After updating to version 2.6, access to the console is impossible; I am left with the following logs in the NGINX console:
2024/12/30 09:58:54 [error] 14720#15060: *73 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 192.168.16.8, server: 192.168.16.5, request: "GET /socket.io/?uuid=6ECFF6E8-9416-419E-8BF5-01B8A7733630&EIO=3&transport=polling&t=1735549133419-0 HTTP/1.1", upstream: "http://127.0.0.1:8080/socket.io/?uuid=6ECFF6E8-9416-419E-8BF5-01B8A7733630&EIO=3&transport=polling&t=1735549133419-0", host: "192.168.16.5"
2024/12/30 09:59:27 [error] 14720#15060: *75 connect() failed (10061: No connection could be made because the target machine actively refused it) while connecting to upstream, client: 192.168.16.5, server: 192.168.16.5, request: "GET /ping HTTP/1.1", upstream: "http://127.0.0.1:8080/ping", host: "192.168.16.5", referrer: "https://192.168.16.5"
2024/12/30 09:59:27 [error] 14720#15060: *77 CreateFile() "D:/wapt/waptserver/repository/wapt/ping" failed (2: The system cannot find the file specified), client: 192.168.16.5, server: 192.168.16.5, request: "HEAD /wapt/ping HTTP/1.1", host: "192.168.16.5", referrer: "https://192.168.16.5"
I don't know why the server is trying to connect to port 8080; there's nothing listening on that port, and to my knowledge, Wapt doesn't use it
Does anyone have any ideas?
- Windows Server 2022 + Wapt Discovery 2.6.0.16174
Thanks in advance,
Re: Error 502 socket.io after updating to 2.6
Published: January 3, 2025 - 5:16 PM
by blemoigne
Could you please verify that you have both Visual Code Redist x64 and x86 installed on your WAPT server?
Once installed, you can restart the WAPT server installation.
Sorry for the inconvenience!
Bertrand
Published: January 6, 2025 - 7:54 AM
by impulse
blemoigne wrote: ↑January 3, 2025 - 5:16 PM Hello,
Could you please check that you have both Visual Code Redist x64 and x86 installed on your WAPT server?
Bertrand
Thanks, after updating the redistributables, I reinstalled the latest version and it works again :D
Good day,
