Page 1 of 1
[RESOLVED] Improved search in the console
Published: January 2, 2025 - 4:12 PM
by smandel
I think the machine inventory search could be improved.
For example, when I search for "24H2" and select all the criteria, I only get a few results... even though I have many more machines listed under 24H2.
It seems the search isn't checking the machines' "Hardware Inventory."
Thank you!
Re: Improving console search
Published: January 3, 2025 - 10:28 AM
by blemoigne
I'm encountering a bug when I select only "hardware" and perform a search.
Thank you for your feedback; I'll pass this on to the development team.
Bertrand
Published: January 3, 2025 - 10:39 AM
by blemoigne
In the meantime, you can go to the equipment inventory on the right, then type "prettyname". You can then drag and drop the value as a column onto the main window, and then sort it (this works for any value in the equipment inventory).
You can also use SQL queries as a filter in the inventory: https://www.wapt.fr/fr/doc/wapt-console ... entory-tab
Bertrand
Published: January 3, 2025 - 10:46 AM
by smandel
Yes, I noticed that too, but I thought there might be a subtlety... :D
Thanks for the tip!
It does the job well!
