Page 1 of 1
[RESOLVED] Package sharing update definition Microsoft Defender Zero Touch
Published: January 30, 2025 - 4:41 PM
by olaplanche
A package already exists on the Wapt store, but I modified it so that the update is completely automatic thanks to the audit function (eliminating the need for the update_package function). The goal is to deploy the update as quickly as possible and without human intervention.
The code is probably messy; this is my first time manipulating dates and times :lol:
Prerequisites:
Each WAPT agent will look for the mpam-fe.exe binary on its WAPT repo to avoid saturating the internet link.
On the WAPT server, you must therefore add, for example, the following line to crontab:
00 20 * * * wget --user-agent="Mozilla" -O /var/www/waptwua/mpam-fe.exe 'https://go.microsoft.com/fwlink/?LinkID=121721&arch=x64'
A brief summary of what the package audit does:
It checks by comparing the date of the binary available on the repository and the binary cached in c:\windows\temp\mpam-fe.xe to see if there is a new version of the binary available.
If the binary does not yet exist in "c:\windows\temp\mpam-fe.exe", it fakes the date in order to force the download.
If the date is different, it downloads the new binary and then checks the signature of the binary (it must be from 'Microsoft Corporation').
Then he installs the new binary.
All that's left is to configure the audit frequency ;)
setup.py:
import requests
import os
from datetime import datetime, timedelta
import time
import waptlicences
r"""
    pass
def audit():
    # Declaring local variables
    osversion = get_os_version()
    repo_url = [r for r in WAPT.repositories if r.name == 'wapt'][0].repo_url
    repo_headers = WAPT.waptserver.head('waptwua/mpam-fe.exe')
    repo_last_modified = repo_headers.get('last-modified')
    repo_last_modified_pattern = "%a, %d %b %Y %H:%M:%S %Z"
    repo_last_modified_date = datetime.strptime(repo_last_modified, repo_last_modified_pattern)
    repo_last_modified_date_loc = repo_last_modified_date + timedelta(hours=1)
    if isfile(r'c:\windows\temp\mpam-fe.exe') :
        file_modTimesinceEpoc = os.path.getmtime(r'c:\windows\temp\mpam-fe.exe')
    else :
        # fake modification time if no bin
        file_modTimesinceEpoc =  int(float('1002387810.4883926'))
    file_modificationTime_str = time.strftime('%Y-%m-%d %H:%M:%S', time.localtime(file_modTimesinceEpoc))
    file_modificationTime_date = datetime.strptime(file_modificationTime_str, '%Y-%m-%d %H:%M:%S')
    # Downloading new bin
    if repo_last_modified_date_loc != file_modificationTime_date :
        with WAPT.waptserver.get_requests_session() as session:
            wget("%swua/mpam-fe.exe" % repo_url, r'c:\windows\temp\mpam-fe.exe', requests_session=session)
    # Check signature bin
    expected_issuer = 'Microsoft Corporation'
    sign_name = waptlicences.check_msi_signature(r'c:\windows\temp\mpam-fe.exe')[0]
    if sign_name != expected_issuer:
        error('Bad issuer %s != %s ' % (sign_name,expected_issuer))
    # Installing bin
    versionfile = get_file_properties(r'c:\windows\temp\mpam-fe.exe')['ProductVersion']
    if get_windows_defender_version() < versionfile:
        run(r'c:\windows\temp\mpam-fe.exe /s')
        error('AntivirusSignatureVersion not in %s' % versionfile)
    print(r'OK: Definition Version is %s' % versionfile)
    return "OK"
def get_windows_defender_version():
    for i in get_antivirus_info():
        if not i["name"] == "Windows Defender":
            continue
        return Version(i['AntivirusSignatureVersion'])
    return Version('0')
Thanks to Simon for his help in putting together this package.
Re: Sharing update package definition Microsoft Defender Zero Touch
Published: February 7, 2025 - 12:28 PM
by dcardon
Hi Olivier,
thanks for sharing :-) . For your information, we're currently working on integrating the SOAP MS-WUSP communication protocol between the Windows Update agent and a WSUS server into the WAPT agent and server. Microsoft has provided a reference implementation [1] in .NET that implements this protocol. It takes into account the updating of Windows Defender definitions. So there might be some interesting new features coming soon. :-)
I'm marking this topic as RESOLVED for now.
Best regards,
[1] https://github.com/microsoft/update-server-server-sync/
