[SOLVED] Secondary deposit certificate issue since update 2.6
Published: February 7, 2025 - 9:47 AM
Since the update from 2.5 to 2.6, I have been getting an error when installing packages on my PCs or servers at remote sites.
Secondary storage facilities are installed on these sites.
Here is the error message on the console:
And the error message on the server where I'm trying to install the 7zip package:
Thank you for your help.
Debian Linux Server (2.6)
Secondary Linux Debian (2.6) repositories (secondary-srv)
Console installed on server 2022
Erreur lors de l'installation de ['srv-bureautique.domain.local(=7)']: erreurs dans les paquets [[('https://srv-wapt.domain.local/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]'), None]Code: Select all
2025-02-07 09:22:03,966 [waptcore WaptTaskManager 5200] CRITICAL Error downloading package from http repository, please update... error : THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]
2025-02-07 09:22:03,966 [waptcore WaptTaskManager 5200] CRITICAL Error downloading some files : [('https://srv-secondaire.domain.local/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]')]
2025-02-07 09:22:03,966 [waptcore WaptTaskManager 5200] CRITICAL Package ltm-7zip [x64_fr_PROD] not installed due to errors : EWaptDownloadError: Package file ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt not downloaded properly.
Erreur lors de l'installation de ['ltm-7zip']: erreurs dans les paquets [[('https://srv-secondaire.domain.local.ltm.bzh/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]'), None], [PackageRequest(package='ltm-7zip',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-2012serverr2', 'win-2012serverr2', 'w-2012serverr2', 'windows2012serverr2', 'win2012serverr2', 'w2012serverr2', 'windows', 'win', 'w'],min_os_version=Version('6.3.9600'),max_os_version=Version('6.3.9600')), PackageEntry('ltm-7zip','24.9-46' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5471, in install\n raise EWaptDownloadError(\'Package file %s not downloaded properly.\' % p.filename)\nwaptpackage.EWaptDownloadError: Package file ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt not downloaded properly.\n']]
2025-02-07 09:22:03,966 [wapttasks WaptTaskManager 5200] CRITICAL Task error Installation de ltm-7zip (tâche #78): Exception: Erreur lors de l'installation de ['ltm-7zip']: erreurs dans les paquets [[('https://srv-secondaire.domain.local/wapt/ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt', 'THttpClientSocket.DoTlsAfter: TLS failed [EOpenSslNetTls TOpenSslNetTls.AfterConnection connect: OpenSSL 30100070 error 1 [SSL_ERROR_SSL (error:0A000086:SSL routines::certificate verify failed) (self-signed certificate #18)]]'), None], [PackageRequest(package='ltm-7zip',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-2012serverr2', 'win-2012serverr2', 'w-2012serverr2', 'windows2012serverr2', 'win2012serverr2', 'w2012serverr2', 'windows', 'win', 'w'],min_os_version=Version('6.3.9600'),max_os_version=Version('6.3.9600')), PackageEntry('ltm-7zip','24.9-46' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n File "C:\\Program Files (x86)\\wapt\\common.py", line 5471, in install\n raise EWaptDownloadError(\'Package file %s not downloaded properly.\' % p.filename)\nwaptpackage.EWaptDownloadError: Package file ltm-7zip_24.9-46_x64_windows_5.0_PROD.wapt not downloaded properly.\n']]Debian Linux Server (2.6)
