Added context menu for VSCODE
Published: February 12, 2025 - 12:59 PM
Hello TrankilIT team,
I modified the tis-vscode package to add VScode to the Windows context menu:
I'm uploading my version of the package in case it helps
import json
bin_name = glob.glob("VSCodeSetup-*.exe")[0]
if control.architecture == "x64":
app_uninstallkey = "{EA457B21-F73E-494C-ACAB-524FDE069978}_is1"
app_uninstallkey = "{F8A2A208-72B3-4D61-95FC-8A65D340689B}_is1"
install_exe_if_needed(
bin_name,
silentflags='/verysilent /mergetasks="!runcode,addcontextmenufiles,addcontextmenufolders,associatewithfiles,addtopath"',
key=app_uninstallkey,
min_version=control.get_software_version(),
timeout=600,
# Adding Firewall Rules
app_name = "Visual Studio Code"
app_path = makepath(installed_softwares(uninstallkey=app_uninstallkey)[0]["install_location"], "code.exe")
run_powershell(f'Remove-NetFirewallRule -DisplayName "{app_name}" -ErrorAction SilentlyContinue', accept_returncodes=[0, 1, 3010])
run_powershell(
f'New-NetFirewallRule -DisplayName "{app_name}" -Group "{app_name}" -Program "{app_path}" -Action Allow -Direction Inbound -Enabled True'
def session_setup():
print("Disabling: Telemetry, automatic updates, surveys")
# Configuration procedure: https://supunkavinda.blog/vscode-editing-settings-json
# C:\Users\username\AppData\Roaming\Code\User\settings.json
# Initializing variables
user_conf_dir = makepath(user_appdata, "Code", "User")
user_conf_file = makepath(user_conf_dir, "settings.json")
user_conf_content = r"""{
"update.mode": "none",
"update.enableWindowsBackgroundUpdates": false,
"update.showReleaseNotes": false,
"telemetry.telemetryLevel": "off",
"typescript.surveys.enabled": false,
"extensions.autoCheckUpdates": false,
"extensions.autoUpdate": false
user_conf_data = json.loads(user_conf_content)
if not isdir(user_conf_dir):
mkdirs(user_conf_dir)
if not isfile(user_conf_file):
print("Creating: settings.json in: %s" % user_conf_dir)
json_write_file(user_conf_file, user_conf_data)
new_user_conf_data = json_load_file(user_conf_file)
new_user_conf_data.update(user_conf_data)
print("Updating: settings.json in: %s" % user_conf_dir)
json_write_file(user_conf_file, new_user_conf_data)
