Page 1 of 1
[RESOLVED] WAPT Exit
Published: February 17, 2025 - 2:22 PM
by smandel
is there a way to limit the number of times users can decline to install updates?
Currently, I give users a 30-second option to postpone the installation.
Is there a way to limit this number of postponements?
Thank you.
Re: WAPT Exit
Published: February 24, 2025 - 12:38 PM
by dcardon
Hi Stany,
there's currently no way to force an update after a certain number of postponements. However, a useful solution would be to install a package that generates increasingly frequent pop-ups if the user hasn't installed anything after a week. The package https://wapt.tranquil.it/store/fr/tis-info-shutdown checks if the PC has been rebooted recently, but it could be modified to check if there have been packages waiting to be installed for more than N days.
Regards,
PS: The package name tis-info-shutdown isn't very descriptive, nor is its description; we'll correct that.
Re: WAPT Exit
Published: February 24, 2025 - 4:04 PM
by smandel
Thanks for the tip, Denis, :D
I'll do that. 8-)
