[SOLVED] Add uninstall to kicad 7 and 8
Published: February 20, 2025 - 1:52 PM
Hello dear,
I just wanted to suggest these additions:
https://wapt.tranquil.it/store/fr/tis-kicad7
Or maybe adapted with key='KiCad ' + str(Version(control.get_software_version(),2)) because you use this in install()?
Same for KiCad8:
https://wapt.tranquil.it/store/fr/tis-kicad8
Many thanks in advance.
softs_to_uninstall = installed_softwares('kicad 7.')
for soft in softs_to_uninstall:
print("Uninstall kicad vers:" + soft['version'])
run(WAPT.uninstall_cmd(soft['key']))Same for KiCad8:
softs_to_uninstall = installed_softwares('kicad 8.')
