Page 1 of 1
[SOLVED] console installation problem in 2.6.0.17177
Published: April 9, 2025 - 2:40 PM
by guigeek
I rushed to install the new version, but I'm getting a strange error during the console installation:
Screenshot 2025-04-09 143844.png (13.5 KB) Viewed 7375 times
I might uninstall/reinstall to try.
Guillaume
Re: Problem installing console in 2.6.0.17177
Published: April 9, 2025 - 2:41 PM
by sfonteneau
This means that a component has locked the libcrypto file (another application) for example, or a wapttray that might have remained running, for example.
Published: April 9, 2025 - 2:49 PM
by guigeek
Yes, but nothing was running.
Anyway, I restarted the PC (I had Windows updates pending).
It works now! I'll be able to test this new version!
Thanks
