Page 1 of 2
[SOLVED] tis-remote-repo-http - Installation failed
Published: April 11, 2025 - 12:19 PM
by silica
I am encountering an error installing the tis-remote-repo-http package on a Windows 11 PC
The Wapt console is back:
installing si-remote-repo-http(=2.6.0.17177-10)
Install wapthttpserver to permit WAPTAgent to become a repository
Remove firewall rule
Copy binary file for wapthttpserver
Register wapthttpserver frontend
Checking if ports 80 and 443 are available
Port 80 is not available
  File "C:\Program Files (x86)\wapt\common.py", line 4296, in install_wapt
  File "C:\windows\TEMP\waptz7bi86u9\setup.py", line 130, in install
  File "C:\windows\TEMP\waptz7bi86u9\setup.py", line 102, in install_wapthttpserver_service
  File "C:\windows\TEMP\waptz7bi86u9\setup.py", line 78, in make_wapthttpserver_config
  File "C:\Program Files (x86)\wapt\common.py", line 3957, in run
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2214, in run
waptutils.CalledProcessErrorOutput: Command 'wapt-get checkport 0.0.0.0:80' returned non-zero exit status 0.
Output:0.0.0.0:80: 1
Exit code: 0
Exit code: 0
IIS features were enabled on this PC (without any particular configuration behind it), I thought that was the reason.
I uninstalled those features but the error message is the same.
Can you help me?
Sincerely
Re: tis-remote-repo-http - Installation error
Published: April 11, 2025 - 3:31 PM
by silica
Indeed, by running this live on the Windows 11 PC:
C:\Program Files (x86)\wapt>wapt-get checkport 0.0.0.0:80
0.0.0.0:80: 1
Exit code: 0
I get the same thing as with the package tis.
Wapt considers this result an error.
Is this an error in the package?
Published: April 11, 2025 - 3:52 PM
by dcardon
Hello Kevin,
as mentioned in the message a little bit above:
There must already be a web server running on the machine in question :-)
Published: April 17, 2025 - 2:47 PM
by dcardon
Hi Kevin,
were you able to fix your problem? Was something listening on port 80?
Regards,
Published: June 10, 2025 - 4:07 PM
by silica
My apologies for the delayed response.
I couldn't find exactly what was listening in port 80.
I ended up replacing port 80 with 8080 in the tis-remote-repo-http
The installation was successful and the packages are synchronizing
But at the end of the synchronization, the repository fails to display an error in the console, and here are the details:
Do you have any idea?
Published: June 11, 2025 - 2:58 PM
by sfonteneau
this happens when you disable WADs on the WAPT server and enable WADs synchronization on the secondary repository.
It tries to download the WADs files but gets a 404 error because the server returns a 404 if WADs is not enabled.
The simplest solution in your case is to enable WADs in the postconf file to see if that resolves the issue.
Published: June 11, 2025 - 6:09 PM
by dcardon
Hello Kevin,
Regarding the port, you can run the following command which gives you the process associated with the port (OwningProcess column):
Get-NetTCPConnection -State Listen | Where localport -eq '80'
Published: June 24, 2025 - 3:11 PM
by silica
This is a System process:
Published: June 24, 2025 - 3:52 PM
by silica
sfonteneau wrote: ↑June 11, 2025 - 2:58 PM Hello
, this happens when the WADs functionality is disabled on the WAPT server side and WADs synchronization is enabled on the secondary repository side.
The simplest solution in your case is to enable WADs in the postconf to see if that resolves the issue.
I just restarted the postconf and I'm getting this error at the end :(
[*] Postconfiguration completed.        │
│ Error while trying to configure Nginx!        │
│ errno = 1  output: Job for nginx.service failed because the control process exited with error code.                                            │
│ See "systemctl status nginx.service" and "journalctl -xe" for details.
Please connect to https://wapt.mon.domaine/ to access the server.
Nginx no longer starts...
(The data is anonymized.)
[root@srv tmp]# systemctl status nginx.service
● nginx.service - The nginx HTTP and reverse proxy server
   Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled; vendor preset: disabled)
  Drop-In: /etc/systemd/system/nginx.service.d
           └─nginx_worker_files_limit.conf
   Active: failed (Result: exit-code) since Tue 2025-06-24 15:31:19 CEST; 2min 55s ago
 Main PID: 1634 (code=killed, signal=KILL)
Jun 24 15:31:18 wapt.mon.domaine systemd[1]: Starting The nginx HTTP and reverse proxy server...
Jun 24 15:31:19 wapt.mon.domaine nginx[49947]: nginx: [emerg] SSL_CTX_use_PrivateKey("/opt/wapt/waptserver/ssl/key.pem") failed (S>
Jun 24 15:31:19 wapt.mon.domaine nginx[49947]: nginx: configuration file /etc/nginx/nginx.conf test failed
Jun 24 15:31:19 wapt.mon.domaine systemd[1]: nginx.service: Control process exited, code=exited status=1
Jun 24 15:31:19 wapt.mon.domaine systemd[1]: nginx.service: Failed with result 'exit-code'.
Jun 24 15:31:19 wapt.mon.domaine systemd[1]: Failed to start The nginx HTTP and reverse proxy server.
Published: June 24, 2025 - 4:19 PM
by sfonteneau
Strange, it looks like someone has modified /opt/wapt/waptserver/ssl/key.pem; nginx can no longer open it
