Page 1 of 2
Disable waptwua
Published: April 25, 2025 - 11:43 AM
by guigeek
I have a script that runs when the network connection changes and checks if the connection is local or not.
If it's local, it changes the WAPT configuration, disabling the `waptwua` field so the PC can access the internet to perform updates.
This all worked fine before version 2.6.0.171177, but since then, when I disable the `waptwua` field, it's still impossible to run Windows updates.
Is this normal? Is it a new feature or a bug?
Thank you for your feedback,
Guillaume
Re: Disable waptwua
Published: May 14, 2025 - 08:57
by guigeek
Anyone?
Can anyone at least tell me which registry entries need to be changed so that PCs can update directly from Microsoft?
Thanks
Re: Disable waptwua
Published: May 14, 2025 - 12:26
by blemoigne
Set the following four keys to 0:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\DisableWindowsUpdateAccess
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU\UseWUServer
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\SetDisableUXWUAccess
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\DoNotConnectToWindowsUpdateInternetLocations
Run gpupdate /force
Restart the “Windows Update” service
Have a good day,
Bertrand
Re: Disable waptwua
Published: May 14, 2025 - 1:21 PM
by guigeek
Thanks! I tried that, I can access the update button, but then I get an error as if the update service is unavailable:
"We couldn't connect to the update service. We'll try again later, or you can check now. If it still doesn't work, make sure you're connected to the internet."
I must be missing something for it to work because the PC has internet access.
Re: Disable waptwua
Published: May 14, 2025 - 1:57 PM
by jlepiquet
could you try applying this package?
tis-clean-softwaredistribution
Re: Disable waptwua
Published: May 14, 2025 - 2:24 PM
by guigeek
THANKS !
but no better :(
jlepiquet wrote: ↑May 14, 2025 - 1:57 PM Hello,
Could you try applying this package?
Re: Disable waptwua
Published: May 14, 2025 - 3:01 PM
by jlepiquet
"Restart the Windows Server 10 (WU) service.
In the command prompt (CMD), run:
`wuauclt /resetauthorization /detectnow /reportnow`.
run
`USOclient refreshsettings`
scan. Then refresh and retry in the Windows Server 10 settings pane."
I found this on a forum. The three commands are independent.
Re: Disable waptwua
Published: May 14, 2025 - 4:29 PM
by guigeek
Thanks, but it still doesn't work :(
Re: Disable waptwua
Published: May 21, 2025 - 08:29
by guigeek
is there anyone from WAPT who might have a working procedure?
Thank you.
Re: Disable waptwua
Published: May 21, 2025 - 09:55
by sfonteneau
when waptwua is enabled, it configures the registry keys here:
and at:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\WindowsUpdate
and disables the Windows Update service.
Therefore, when waptwua is disabled, the process is reversed.
If the key HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\SetDisableUXWUAccess = 1 and waptwua is "disabled",
then delete the keys
and HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate
, and then restart the Windows Update service.
Normally, in your use case, I would strongly recommend using secondary download rules.
You can tell the computer to use http://download.windowsupdate.com/micro ... /wsusscan/ with a secondary download rule.
