Page 1 of 1
[RESOLVED] Web access after 2FA activation
Published: May 14, 2025 - 09:14
by dsi_oll
I can no longer access the WAPT webpage.
Since configuring 2FA, it no longer allows me to enter my password for the web access page.
Fabien
WAPT Discovery Edition 2.6.0.17226
Re: Web access after 2FA activation
Published: May 14, 2025 - 09:50
by Jarnaud
Yes, this is normal because you need to change how you enter your password.
You can find this information in our documentation:
https://www.wapt.fr/fr/doc/wapt-console ... pt-console
The section that directly concerns you regarding how to connect to your WAPT server URL is as follows:
When you enable TOTP, you must take into account certain changes in behavior:
When connecting to the WAPT server URL, the OTP (One-Time Password) code must be added between curly braces. Example: password{OTPcode}.
When registering a new agent machine, use the command `wapt-get register --with-otp`. Identify the login and password as password{OTPcode}.
Best regards
Published: May 14, 2025 - 09:58
by dsi_oll
Perfect.
Thank you so much for this answer.
I hadn't been able to find this information.
Have a great day.
Best regards,
Fabien
