Page 1 of 1
[SOLVED] Problem with the tis-remove-windows-appx-template package
Published: July 16, 2025 - 08:36
by Mikael S
In the session setup, you call the 'appx_to_uninstall.json' file on line 55.
However, the cache has since been cleared, and the file along with it. It needs to be copied elsewhere for the session setup to work on all sessions.
Regards,
Re: Problem with the tis-remove-windows-appx-template package
Published: July 22, 2025 - 11:10 AM
by blemoigne
Hi Mikael,
Yes, there was a small typo, it's been corrected and the package will be available soon. Thanks for letting me know.
Have a good day,
Bertrand
Published: July 22, 2025 - 11:21
by blemoigne
In the meantime, it is available on the testing repository: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Published: July 22, 2025 - 5:02 PM
by dcardon
Hi Mikaël,
does the package update resolve the issue?
Regards,
Published: July 23, 2025 - 2:23 PM
by Mikael S
Yes, that's all good then.
Regards,
Published: July 23, 2025 - 2:49 PM
by dcardon
Hello Mikaël,
thank you for reporting the bug and for the validation :-)
. Regards,
