Page 1 of 1
WAP client update on machines
Published: March 15, 2016 - 3:07 PM
by knpc
Having upgraded to version 1.3.5, I wanted to update the WAPT client on the machines, but I'm getting an error message on the console.
What do you think?
Thanks
, Knpc
Re: WAP client update on machines
Published: March 15, 2016 - 5:11 PM
by sfonteneau
The "update wapt client" function is no longer available since version 1.3.5.
The button has not been removed.
To update your wapt client, you must use the waptupgrade package, which is automatically generated when you create your personal installer. You simply need to apply this package to the machine you want to update.
- Simon
Published: March 15, 2016 - 6:39 PM
by knpc
Hi,
I updated from version 1.2.3 to 1.3.5 and I don't see this package.
I see a package called mtt-waptupgrade_1.2.3.2-1496_all.wapt.
Where can I find, download, or create it?
Thanks
Published: March 16, 2016 - 08:41
by sfonteneau
Hello
, you need to regenerate a custom waptsetup. These steps must be performed from a 1.3.5 console:
http://dev.tranquil.it/scenari/guide_ad ... nsole.html
Note that you do not need to regenerate the private/public keys; you should have already generated these keys previously and need to reuse them.
After generating the custom waptsetup, the package mtt-waptupgrade_1.3.5.0-1496_all.wapt should appear in your repository.
Published: March 16, 2016 - 2:08 PM
by knpc
Thank you! Everything works perfectly.
Great product, great forum, and especially a super knowledgeable user.
Thank you all.
PS: I know I'll probably have other questions later. :D
