Java Packages
knpc
Registration: Nov. 20, 2015 - 4:40 p.m.
March 16, 2016 - 4:50 PM
Hi everyone,
yes, it's me again. :lol:
I downloaded the Java 8.73 package, but during deployment, the security settings from the previous Java version disappeared from the deployed 8.73 version.
- Has anyone else encountered this problem?
- Is there another package that preserves the security levels and settings?
- Is it impossible to uninstall the old version?
- Can I install only the 32-bit version? (The old one was 32-bit)
- Is there just a 32-bit package available?
Thanks,
Knpc
knpc
April 21, 2016 - 2:52 PM
I'm following up with my message because I recently encountered this problem again while installing the Java 8.77 package. The URL listed in the security section had disappeared.
Is there a way within the package to have Java install first, retrieving the security settings, and then uninstall the old version last?
Thank you
, Knpc
